Aluminum rear bumper?
Old Mar 21, 2007 | 09:51 PM
Stevo's Avatar
Car: Pair of 92 Z28s
Did they actually make these or not? For camaros. I cant find any solid info on them. As well as the car i got my alum front bumper had a steel rear bumper. Ive seen pictures of the fronts but never of the rears. If i cant find one im thinking about removing the stock one and cutting off the corners so its square with the frame and also getting rid of the egg crate. Reason im not adding it to the front is I already have a cracked repaired front bumper and if i ever get in another fender bender ill replace the bumper as well i would with the rear. That stuff is easily worth 3-5 pounds. Every little bit counts Car is a street car too so i dont want to remove them completely.
Here is the alum front bumper i got on tonight.
Glad i got it in, let me get a chance to fix and paint other stuff. Undercoated and painted a lot of small stuff. Tommaro the factory manifolds as well as the rest of the exhaust is coming off. Going to try to re-align my fenders better tommaro.
sweet 70 degree weather is coming back!
Old Mar 22, 2007 | 12:03 AM
CYARS92's Avatar
Car: 92 Camaro RS, 72 Camaro SS
Engine: 305TBI, til it pukes
Re: Aluminum rear bumper?
That's pretty cool. I had no idea they even made the fronts! What years were they on?
Old Mar 22, 2007 | 12:35 AM
Stephen's Avatar
Car: 87 GTA
Only early, early 3rd gens, AFAIK.
I've got one off a 84Z28. The very corner is slightly bent, but fixable. I just never put the effort into straightening it out.
I don't know of any later years, aluminum ones being made. You could always do what a buddy of mine did...He took out the front bumper support, and built an aluminum tubular brace. Shaved some weight, but has no crash protection now. Of course, it's not much of a street car anyways now. Mainly autocross.
Old Mar 23, 2007 | 03:19 PM
Stevo's Avatar
anyone else know about the rear bumpers?
Old Mar 26, 2007 | 10:58 AM
Daniel U's Avatar
Car: '88 Camaro
Engine: 5.7 L98
Axle/Gears: Borg Warner 9 bolt w/3.27 lim. slip
I wonder if you can order these from GM? Probably lots of $$, but I wonder if they still make/stock them? What year/model for the front aluminum bumper? I'm more interested in the front end wieght. I can't get enough over the rear. The lighter the front the better, for me.
Old Mar 26, 2007 | 11:08 AM
Stephen's Avatar
Car: 87 GTA
From what I understand, '84 was the last year for the aluminum ones.
One of these days I should get rid of mine. It has been collecting dust for about 6 years now, behind my shed, on some saw horses.
I never thought to check a magnet of the rear bumper metal. 99.999% likely steel anyways. I've never even heard of an aluminum rear.
Old Mar 26, 2007 | 11:18 AM
Daniel U's Avatar
Car: '88 Camaro
Engine: 5.7 L98
You have an alum. one? How much $ for it? Is it straight? I'm in CA. @ 93446 zip. Thanks, Daniel U
Old Mar 26, 2007 | 12:14 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
because of this thread, yesterday I was trying to match up the firebird aluminum one I have onto my parts camaro. Looks like if I redo the plastic crumple material, it might work.
Old Mar 26, 2007 | 12:26 PM
Stephen's Avatar
Car: 87 GTA
Not perfectly straight. It was on a 84 Z28, that took a left hand curve too fast, and slipped sideways off the road, into the deep ditch, taking out the passenger side door, etc.
I took these pics of the brackets that I have on hand...You can see the bend is at the very end, and very slight. Being aluminum, I'm sure straightening it would be a breeze.
I found the pics of the main support. The ben is so slight, you can barely make it out, in the first pic.
Attached Thumbnails Aluminum rear bumper?-aluminum-bumper-1001.jpg   Aluminum rear bumper?-aluminum-bumper-1002.jpg   Aluminum rear bumper?-aluminum-bumper-1-4
Old Mar 26, 2007 | 04:16 PM
Daniel U's Avatar
Car: '88 Camaro
Engine: 5.7 L98
Has anyone wieghed these to see the exact amount of wieght savings?
Old Mar 26, 2007 | 04:20 PM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
my 85 front steel bumper by itself was exactly 24 pounds
Old Mar 26, 2007 | 05:53 PM
Daniel U's Avatar
Car: '88 Camaro
Engine: 5.7 L98
Alright Stephen, bust out the scale and satisfy my curiosity, Please!
Old Mar 28, 2007 | 02:31 PM
Dale's Avatar
Engine: 350 S-TPI
I know an 84 firebird alumn front bumper is 15.
Old Mar 28, 2007 | 02:39 PM
Stephen's Avatar
Car: 87 GTA
Did 'birds ever have aluminum ones though? If it was 9 lbs lighter than the other one posted, it sounds like it is aluminum.
Old Mar 28, 2007 | 03:05 PM
Stevo's Avatar
Its about a 10-15 pound savings switching from the steel to aluminum. Little more if you leave the eggcrate off like i did. Closer to 15lbs. Worth it if you have one and are willing to take the front bumper cover off.
Old Mar 28, 2007 | 08:20 PM
Dale's Avatar
Engine: 350 S-TPI
I never knew camaros had aluminum ones I'm thinking about trying to fit this bird one onto my camaro since I have to replace the nose anyway.
Old Mar 28, 2007 | 08:26 PM
Stephen's Avatar
Car: 87 GTA
The one I have was on a 84 Z that was totaled, by sliding sideways off a curve...into a deep ditch.
I should be able to get to it this week, maybe Sat.
Old Mar 29, 2007 | 03:14 PM
Ucantcme57's Avatar
So what is everyone thinking 85 an earlier camaros have aluminum front and rear bumpers?
I am going to be stripping my car down soon for paint, she's a 86 Iroc, I would love to know what I have and if they are steel, what years should I be looking for these stocks aluminum ones?
Old Mar 29, 2007 | 03:18 PM
Stephen's Avatar
Car: 87 GTA
I believe it is '85 & earlier, not positive.
Use a magnet on your '86, and let us know.
Old Mar 30, 2007 | 12:26 PM
chevylover5's Avatar
Car: 1992 Camaro vert
Engine: 355
Axle/Gears: 10 bolt... not blow up yet
i know for a fact that my rear bumper is steel cause its rusted like a **** and i need to get aother one in order to pass inspection... does anyone know where i could get one?
Old Mar 30, 2007 | 01:59 PM
Dale's Avatar
Engine: 350 S-TPI
I can get them all day long here at the junkyard. They charged me 35 for the front firebird one I have, guessing would be same for camaro rear. Shipping would rape you though... Unless you live around a grayhound bus station and dont mind going and picking it up.
I am having to take the one off my parts car and put on my new one because it was a northern car and rusted to hell as well.
Old Mar 30, 2007 | 02:01 PM
Engine: 355
im from PA i know the feeling...
um i was priced in a catelog for $35 for a factory replacement, Ill prolly end up just ordering it and driving to jersey to pick it up.
Old Mar 30, 2007 | 03:05 PM
Dale's Avatar
Engine: 350 S-TPI
damn, I'm getting ripped on parts then.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
z28addict8490
Aug 7, 2015 08:48 PM
