tar removal on GFX/ wheelwells???
Old Apr 9, 2007 | 01:54 PM
mlaskow86's Avatar
Car: 1989 Trans Am
Engine: 5.0 TPI
Transmission: 5 Speed Manual
Axle/Gears: Stock Rear End
the previous owner of my car had a heavy foot, as a result theres about 1/8 of an inch of tar/rubber on the rear GFX and all around the wheel. im starting to sand/paint and its a real PITA sanding layer after layer off. Does anyone have suggestions on a spray to get it off or a method of removal? ive tried the old faithful carb cleaner and a heat gun but i feel the gfx will melt before the tar and the carb cleaner didnt really do much either... any help is great
Old Apr 9, 2007 | 06:32 PM
The_Wraith's Avatar
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
Re: tar removal on GFX/ wheelwells???
Acetone
Old Apr 9, 2007 | 07:08 PM
online170's Avatar
Car: 1987 Firebird
Engine: 355
there was thread on here a couple days ago, and aparentlly WD-40 is AMAZING. Just spray it on, let it soak, and it pretty much wipes off. But if your talking actuall in the wheel well, thats a bit tougher. Youll pretty much have to scrape.
Old Apr 9, 2007 | 07:50 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Sounds like quite a build up. You might need to resort to some scrapping no matter what product you use. I use spay-able goo gone, elbow grease, non metalic scapers and lots of old rags.
Old Apr 9, 2007 | 10:15 PM
mlaskow86's Avatar
Car: 1989 Trans Am
Engine: 5.0 TPI
tomorrow i will try sprays on the gfx and today i was able to get most off the wheel wells with a putty knife. there is still some on the lip of the quarter panels but i dont wanna use a knife on the paint.. hopefully the wd40 works
Old Apr 10, 2007 | 01:04 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
I'd vote WD40 also. Great as a solvent and won't damage paint as acetone will.
Lon
Old Apr 10, 2007 | 10:44 AM
mlaskow86's Avatar
Car: 1989 Trans Am
Engine: 5.0 TPI
not too worried about the paint, im changing the color anyways. i did a little bit with wd 40, didnt work as well as i thought it would but it did loosen it a lot. gonna get some acetone tonight maybe
Old Apr 10, 2007 | 01:02 PM
online170's Avatar
Car: 1987 Firebird
Engine: 355
well if youre not worried about the paint, get some deisel gas, or paint stripper, or some nasty chemical like that, and let it dissolve it away. A wire brush also works, but u gotta put in some elbow grease.
Old Apr 11, 2007 | 01:53 AM
83 Crossfire TA's Avatar
Stick with WD40, kerosene or even gasoline. Acetone, laquer thinner and the like will at least soften if not ruin your paint, and will soak in and cause solvent pop on the new paint job.
Old Apr 11, 2007 | 10:34 AM
Iroctopless's Avatar
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
Sikkens antistatic degreaser works well.
Old Apr 11, 2007 | 12:59 PM
lonsal's Avatar
I don't recommend gasoline as a solvent. Also it goes without saying that you'll want to do this in a well ventillated area. You don't want the fire department to have to finish the job for you because the project got a little hotter than anticipated.
Lon
Old Apr 11, 2007 | 04:40 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
WD-40, Bug and Tar remover, or Simple Green is what i would try.
Old Apr 11, 2007 | 06:08 PM
mlaskow86's Avatar
Car: 1989 Trans Am
Engine: 5.0 TPI
i hammered down with some wd 40 and got most of it off lastnight. thanks for the input guys. always appreciated.
Old Apr 11, 2007 | 08:46 PM
I wouldn’t recommend it, just like you shouldn’t wash down parts in it, but it does work, you probably have it around, and to be honest, as long as you’re not smoking at the time it won’t cause a problem. Lets face it, whatever you’re using you’re going to soak into a rag and wipe around, and EVERYTHING that will really cut the tar well is extremely flammable when soaked into something.
Old Apr 11, 2007 | 09:12 PM
mlaskow86's Avatar
Car: 1989 Trans Am
Engine: 5.0 TPI
i try to stay away from using gas as solvents.... kinda pricey also it dosnt mix well with blunts
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
ctoledo0834
Sep 18, 2015 04:16 PM
Stroopwafel
Sep 11, 2015 06:38 AM
