It finally happened.... :(
Old Apr 22, 2007 | 11:14 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
After 4 years of driving without any sort of fender bender..... i lost control of my car about a week ago and plowed a fire hydrant......
Smashed up the front bumper cover, broke the hi beam lens ( still works tho ), moved in the radiator support, bent the from subframe, tie rod bent, Dented the floor pan moving the pass seat and the center console, ripped a hole in the floor..... blew out two tires and ripped off my exhaust.
after all that i swapped on two spare wheels, zip tied the radiator back, and drove home.
third pic down shows the hole in the floor... kinda bad angle... but its dented up alot
Old Apr 22, 2007 | 11:22 PM
energycontacts's Avatar
Re: It finally happened.... :(
That looks pretty bad. If you are going to part it, let me know. I need some parts.
Old Apr 22, 2007 | 11:47 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
more than likely when i get my stuff in order i will swap the T-5 into my white camaro and part most of this one out. I also have a maroon car for parts that i'll be listing soon if this local guy doesn't hurry up and say something.
Old Apr 22, 2007 | 11:50 PM
92RS(real slow)'s Avatar
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
ouch that sucks well at least you have a few other thirdgens to work with
Old Apr 22, 2007 | 11:53 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
lol yea.... it actually runs about fine... i drove it home... im in the process of putting an exhaust on it to get me around while a prepare the white camaro for the swap.
all i need is to fix some oil leaks on the 357 and get a flywheel that'll fit it and im good to go..
untill then its to and from work only in the green car.... its a bit of a scary thought to know the SF is ding up
Old Apr 24, 2007 | 05:20 PM
Saigon-bob, that maroon car you got, does it have a good driver fender? How about the hood, is that in good shape and is it an IROC hood? I live in Kissimmee too and need some parts if you are selling them. Please let me know.
Old Apr 25, 2007 | 01:16 PM
Brisk's Avatar
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
damn, thats was a gooder one wasn't it?! Thankfully your not injured so thats the important part. It looks like that front tire was pretty bald?!
Old Apr 25, 2007 | 01:36 PM
burn0ut305's Avatar
Car: z28
Transmission: pro built 700r4 (road racing kit)
how did it happen???
Old Apr 25, 2007 | 03:13 PM
rwdtech's Avatar
Car: 1991 Z28 (sold)
damn that sucks....looks like someone needed new tires though! so is the car done? at least you went 4 years without a fender bender
Old Apr 25, 2007 | 11:35 PM
GarageToys's Avatar
Car: 89 Iroc Hardtop
Engine: LB9 w/G92 Pkg
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt, 3.45
Is that the fuel line ziptied to the upper radiator hose and laying on top of the radiator? By any chance did your wreck have anything to do with the car vapor-locking?
Old Apr 27, 2007 | 09:38 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Yea I work next to a tire shop so they gave me 3 Goodyear RS-A tires for free, used but with tons of tread.
um nope the tires were'nt bald untill i drove to my friends house on flats.
How did it happen, well this is going to sound really stupid but it was a case of rear end swings out one way ( nothing i can't deal with ) and then the car caught traction outta no where and swung around the otherway ( normally wouldn't have been bad save the fact of close proximity to the corner ). The car hopped a curb, went thru a sign, then up over the fire hydrant. I literally hit it and the car hopped over it and onto it. It was laying on the sidewalk lol.
Also yes i realize that it a really bad spot for the fuel line but not a sign of vapor lock yet. It was done like that as an emergency measure when i converted from TBI to Carb, my vats module was taking a **** on me and left me stranded too many times so i decided no more computer.
Old Apr 28, 2007 | 09:47 AM
DigitalMonarch0's Avatar
Car: 1988 Pontiac Firebird Trans Am Vert
Engine: 5.0L TPI
Transmission: 5-Speed
Axle/Gears: 3.08
Car looks relatively dry...
Did the fire hydrant break and spray water?
Old Apr 28, 2007 | 10:22 AM
CreepingDeath94's Avatar
Car: '87 Trans-Am
Engine: LB9 (305 TPI)
Axle/Gears: 3.42 or 3.73..figuring it out still
You could have just over ridden the VATS system. Either wire past it, or hardwire the proper resistance into the wire...either way, sorry to hear about that. hope everything works out here.
Old Apr 29, 2007 | 02:45 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
The fire hydrant broke and was like 2 ft away from its original spot on the floor but no water.....
and the VATS had previously been by-passed so i had no other choice other than to replace or cut out.
Rocket-Doc
Nov 14, 2015 02:08 PM
Antips16
Oct 30, 2015 06:42 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
