I want to remove the body stripes...
Old Apr 30, 2007 | 01:07 PM
Camaro355Z28's Avatar
Car: '86 Z28
Engine: 355
Transmission: 5 speed
Axle/Gears: standard 3.23
the three stipes that go around the bottom of my car are all cracked and small portions are missing so I want to remove them all together. I've seen other people here with new paint jobs of all 1 color that I'm sure have had to remove the stickers themselves so I'm asking what is the easiest way of removing them? I started using decal remover and a razor blade but it is taking forever. I'm looking for simplicity here. I plan on painting the whole car black 'cause it needs it but I dont know when, so would sanding them of be an option? Any help would be appreciated...
Old Apr 30, 2007 | 03:20 PM
Pocket's Avatar
Car: 91 Trans Am
Re: I want to remove the body stripes...
Heat gun or some aggressive sandpaper
Old Apr 30, 2007 | 04:55 PM
Car: '86 Z28
Engine: 355
well the heat gun is removing the sticker a bit easier, but leaving the adhesive. guess I'll have to use a little adhesive remover and a little more effort, but I'm feelin' a little lazy right now so I'll do it tomorrow
Old Apr 30, 2007 | 07:47 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
I work with vinyl as part of my job. A heat gun is the best method of getting it off. For the residue, the best product I have ever used is called "Rapid Remover". You might be able to get it online, but in stores, probably not. http://www.rapidtac.com/products/remover.html
People say use WD40, and while I have had to resort to this at times, Rapid Remover makes the adhesive crap literally melt off of the surface after 60 seconds. Just make sure you clean the area afterwards, as it leaves behind a greasy residue. (any mild detergent will do fine here).
Old May 10, 2007 | 08:34 PM
gixxer92's Avatar
Car: 1986 IROC, 2017 Silverado
Engine: 7.0L, 6.2L
Transmission: Tremec Magnum, 8L80
Axle/Gears: 3:23, 3:55
Rubber erasure wheel, mounts on a drill takes the decal off and rewax the car afterwards.
Old May 10, 2007 | 08:53 PM
Stephen's Avatar
Car: 87 GTA
That is the trick. It will remove the stripe and the adhesive, without hurting the paint a bit.
I've been doing vinyl work for over 6 years professionally, and the smart eraser type tool has saved me 100 times over. I bought a 5 year old black 97 Tahoe in 2002, and the factory pinstripe came right off, the paint looked perfect afterwards, and you'd never know it had been there at all.
Like the Astro Smart Eraser on this page. Any body paint/shop store would have one.
Old May 11, 2007 | 09:11 AM
Magsls1's Avatar
Car: 91 Z-28
Transmission: 700R4, T-56 future
A heat gun will do a decent job if your decals weren't old and cracked. On an old Wrangler I had it worked well on some of the decals but not all. On my Iroc they were basically painted over and had to use a razor blade and lots of Goof-Off over and over. Even if they do come off well with a heat gun it is probably still a good idea to use something like a goof-off to make sure all the glue is removed.
These methods are definitely time consuming and will destory the finish so I'd say go with other people's ideas first.
Old May 11, 2007 | 12:51 PM
Car: '86 Z28
Engine: 355
well I'm not too worried about my paint finish because it's so worn and faded, most of it is beyond the primer layers. I may just try goo gone for now just to get rid of the adhesive, but I do know that wd-40 did nothing...
Old May 20, 2007 | 04:28 PM
intex1982's Avatar
Car: 89 formula/00 z28
Engine: carbed 350/ls1
Transmission: 700r4/ a4
Axle/Gears: 3.23 posi/ 3.73 posi
Rubber erasure wheel where can i get one
Old May 20, 2007 | 04:43 PM
Stephen's Avatar
Car: 87 GTA
See above...#6. I told where, and provided an online link to order one.
Old May 20, 2007 | 06:20 PM
Stephen's Avatar
Car: 87 GTA
Here's the pics of my Tahoe during and afterwards. A good wash, a little polish, and it was like it had never been there.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
stalkier
Aug 21, 2015 01:54 AM
3rdgenparts
Aug 8, 2015 07:09 PM
