surface rust
Old May 1, 2007 | 07:18 PM
maroon85's Avatar
Car: '85 Firebird
Engine: 2.8 V6
Transmission: stock BW 5 spd.
Axle/Gears: stock 3.42
surface rust
how do you keep surface rust from spreading/getting worse, without cutting or replacing the panel?,
Old May 1, 2007 | 07:31 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
Re: surface rust
if its just surface rust then sand it out.
Old May 1, 2007 | 07:37 PM
VenomX-87's Avatar
Car: 1984 Trans-Am WS6
Engine: WAS: 5.0HO, SOON: ZZ383-425HP.
Transmission: 700R4 with shift kit
Re: surface rust
lightly sand the rust off and coat the effected area with a anti rust paint eg: Killrust (Australian brand tho, you will need to find something similar).
Old May 1, 2007 | 08:00 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
Re: surface rust
Ive been using rustoleum rattle can primer, its pretty good, and wet-sandable.
Old May 2, 2007 | 12:32 AM
maroon85's Avatar
Car: '85 Firebird
Engine: 2.8 V6
Re: surface rust
I've stripped the surface rust & the area around it to the bare metal, & threw a quick coat of primer on it, so it won't rust while I'm working on other parts of the car,
the part where the rust was is rough, how do I smooth it out so I can paint the car?
Old May 2, 2007 | 01:04 AM
VenomX-87's Avatar
Re: surface rust
i duno about paint over there but here primer is not water proof, over time it will rust unless you put a top coat over it.
Old May 2, 2007 | 01:53 AM
maroon85's Avatar
Car: '85 Firebird
Engine: 2.8 V6
Re: surface rust
if you leave bare metal out in the rain & weather for a few days, what happens?... it rusts.
the "quick coat of primer" is only temporary, to protect the bare metal so I can work on other rust spots & other parts of the car that need work, getting it ready for paint, once all the rust & stuff is taken care of, the car will be sanded, re-primered, re-sanded & painted with Rustoleum car paint.
Old May 2, 2007 | 04:40 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
Re: surface rust
just put some body filler on the rough part, and sand it smooth.
Old May 2, 2007 | 05:22 PM
maroon85's Avatar
Car: '85 Firebird
Engine: 2.8 V6
Re: surface rust
thanks,
should I patch or bondo small holes in the body?
Old May 2, 2007 | 05:29 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
Re: surface rust
depends how small the holes are, if there very small, I think bondo would do it.
Old May 2, 2007 | 06:34 PM
strokermotor91's Avatar
Car: 91 Camaro RS
Engine: Small Block
Transmission: TH350 w/ 3000 stall convertor
Axle/Gears: 3.73 w/ powertrax locker
Re: surface rust
you might even be able to weld the holes shut. Not too big of a deal.
Old May 2, 2007 | 06:50 PM
VenomX-87's Avatar
Re: surface rust
Is the rust seen or hiden?
Because if there are like 1 or 2 holes in a hidden area like where youre spare wheel is clean all the rust up drill them to they are clean round holes, Coat them in a anti rust paint then put some ruber gromits in them that way if water ever pools in that area again (that would have been why it rusted in the first place) you just need to pop the gromits out and you got drain holes.
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Fireslash
Apr 11, 2016 06:43 PM
FueledSoul
Sep 30, 2015 09:18 PM
tcflint
Sep 27, 2015 05:58 PM
