Match paint color??
Old May 15, 2007 | 09:58 PM
v10viper04's Avatar
Car: 84' Corvette, 96' Caprice
Engine: LT1, L99
Transmission: T-56, 4L60e
Axle/Gears: 3.07 POSI, 2.93 Open
Match paint color??
how can i match the paint color of my Camaro if its not the original paint? Any help would be appreciated. Thanks
Old May 15, 2007 | 10:05 PM
lasher_350's Avatar
Car: 1987 Trans Am GTA
Engine: 5.7 L98
Axle/Gears: 9 bolt 327
Re: Match paint color??
Drive it to a paint shop and have them analyze it and mix up some paint to match exactly
Old May 16, 2007 | 06:26 AM
v10viper04's Avatar
Engine: LT1, L99
where around canandaigua, NY is there a paint shop?
Old May 16, 2007 | 07:19 AM
lasher_350's Avatar
Engine: 5.7 L98
Well, since I'm in Kansas, I can't quite direct you to one in your area...I'm sure they make a phone book yellow pages directory, you could look under automotive paint in there and find one or two at least
Old May 16, 2007 | 10:48 PM
v10viper04's Avatar
Engine: LT1, L99
Ok thanks, i'll see what i can figure out.
Old May 17, 2007 | 12:22 AM
Mikz86TA's Avatar
Car: '86 Trans Am and '03 S-10
Engine: 355ci and 4.3l
Transmission: 700R4 and NV3500
Axle/Gears: 7.625/3.42 Auburn and 8.5/3.08 Gov-
Most R&M, DuPont or BASF authorized paint shops have very accurate color books with sample chips in them. If the paint has been on for a while and I see its Red, then it couldve faded. If you are just fixing a booboo then the chip book at the car would be best. If its a total re-paint, and you seek the orig color, the ServiceOptions decal in the console has a paint code at the bottom. Will be a WA L #### - U #### and have most likely BC/CC at the far end. The U is the upper/main color and the L is the lower color. If it was a solid colored car, the L is the same as the U. If it had a diff colored lower then L is different. BTW, BB/CC means BaseCoat and ClearCote. Also a GM dealer parts counter can decode the OEM color code. Hope this helps
lee01
Apr 9, 2016 01:56 PM
69 Six Pack
Oct 5, 2015 07:51 PM
hectre13
Sep 8, 2015 03:38 PM
LT1Formula
Aug 20, 2015 09:36 PM
ElPaleterro85
Aug 13, 2015 03:49 PM
