rubber piece
Old May 17, 2007 | 01:55 PM
north_oakland's Avatar
Car: 1989 Camaro
Engine: 2.8L
rubber piece
I have a 89 camaro and my car is leaking in the back seat. I have new weather stripping around the trunk and I know that is not where the leak is coming from. I think the leak is coming from the trunk hinges. It looks like it is leaking from the rubber pieces that are between the body and the hinges. I cant find those rubber pieces does any1 know what they are called or any ideas on where to get them thanx
Old May 18, 2007 | 01:46 AM
Car: 1989 Camaro
Engine: 2.8L
Re: rubber piece
any1 have any ideas? any help?
Old May 18, 2007 | 06:25 PM
cdoyle's Avatar
Re: rubber piece
Mine was leaking from there too, if you remove the bolts for the hinge at least on mine. From the factory was a goo type around the head of the bolts to keep water out. Over time it has worn away and water was dripping in around those bolts. I took them out, applied some silicone and then tighten those bolts back up. Once the silicone dried it made a new seal.
That seemed to stop those leaks.
Old May 18, 2007 | 08:40 PM
2kflhr's Avatar
Car: '68 396 SS/RS, '02 SS
Re: rubber piece
That should fix it if it's leaking around the bolts. If it's the gasket you'll probably have to cut it out yourself. LMK if you can't find any of the gasket material.
Old May 21, 2007 | 12:39 AM
Car: 1989 Camaro
Engine: 2.8L
Re: rubber piece
ok thanx im gonna try to just seal aroud the bolts i think tha is where its leaking from
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
gta_knight
Sep 23, 2015 04:59 PM
roysatikas
Sep 22, 2015 08:15 PM
gta892000
Sep 16, 2015 12:37 AM
armybyrd
Carburetors
25
Sep 13, 2015 01:49 PM
