what's this piece called - side window weatherstrip support rail
Old Jun 10, 2007 | 03:34 PM
Camarogeddon's Avatar
Car: '85 Camaro Z28
Engine: 350 carbed.
Axle/Gears: 9 bolt, 4.11's
I've been having trouble with getting a proper seal on the passenger side window, the weatherstrip that is supposed to seal the rear vertical part of the window does not follow the window properly.
after a little poking around and comparing it to the other side, i noticed that there is a metal rail missing from the passenger side, that apparently support the weatherstrip, creating the proper arch to follow the window.
is this piece part of the weatherstrip kits, or is it an item i would have to scrounge various junkyards for (even better, does anyone have the part number, or know of anyone who ships international that may supply this piece?)
see attached photos, any insight is appreciated
Attached Thumbnails what's this piece called - side window weatherstrip support rail-untitled-1.jpg   what's this piece called - side window weatherstrip support rail-untitled-2.jpg   what's this piece called - side window weatherstrip support rail-untitled-3.jpg
Old Jun 10, 2007 | 03:35 PM
Car: '85 Camaro Z28
Engine: 350 carbed.
Re: what's this piece called - side window weatherstrip support rail
a view of the resulting gap between the weatherstripping and the window itself
Attached Thumbnails what's this piece called - side window weatherstrip support rail-untitled-4.jpg
Old Jun 11, 2007 | 11:51 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
i believe they call that a drip rail molding, i'm sure someone on the board has one or you can get one from a junk yard somewhere.
1992 Trans Am
May 10, 2023 07:19 PM
Terrell351
Jun 13, 2021 01:13 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
pfsteichen
Feb 9, 2016 06:59 PM
