[90-91] - How does needles light up on instrument panel?
Old May 29, 2004 | 09:11 PM
camarosource's Avatar
Car: Custom 1992 Camaro Z28 25th Anniver
Engine: 5.7L V8 350 L98 TPI
How does the needles on the instrument panel on the 1990-1992 Camaro's light up? I don't see any side lights lighting up the ornage colored needles, and I don't see a light behind them. They light up but where is this light coming through?
The reason I ask this is to find out exactly WHY needles do not light up the same with aftermarket indiglo, reverse indiglo, nor white faced guages. Seems that the needles are all hard to see once these factory intrument panels are replaced with one of the above. Why exactly are they not nightly up the same?
Old May 29, 2004 | 10:47 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
They are backlit from the cluster lights. The needles are clear and prisim shaped. There is paint on the backside of the needle to give its color.
Attached Thumbnails [90-91] - How does needles light up on instrument panel?-backlit.gif
Old May 29, 2004 | 11:23 PM
WOW! You did not draw that up just for this message did you?
I understand how the needle lights up now.. Could someone please explain why changing the "guage face" itself would cause the needles to no longer light up?
When you see cars with the aftermarket guages like the white faced ones, or indiglo/reverse indiglo guages, the needles are always dark and hard to see. If the guage has "halo's" where the needle is, then the halo tends to show a black line where the needle is.
Old May 30, 2004 | 10:56 AM
deadbird's Avatar
Engine: TPI 305/ v6
Yea.. I did but, it only took like 2 mins using MS paint. Less time then it would take for me to describe it anyways.
I vaguely remember this being talked about when people first started getting the indiglo gauges. IIRC, you take the old 194 bulbs out which lit the needles. The glow from the gauges just isn't strong enough to light the needles like the bulbs did.
Here's a link that may interest you though...
http://www.angelfire.com/fl5/import/indigloneedles.html
Old May 30, 2004 | 12:22 PM
CaysE's Avatar
double post..
Old May 30, 2004 | 12:25 PM
CaysE's Avatar
Wow!! Nice!!!
Attached Thumbnails [90-91] - How does needles light up on instrument panel?-indigloneedles.jpg
Old May 30, 2004 | 02:58 PM
but aren't these guages something that SLIPS OVER TOP of your other one.. so the bulbs are still there...
Old Jun 8, 2007 | 12:26 PM
camaro91boy's Avatar
Car: 95 z28 camaro or 92 k5 Blazer
Engine: LT-1 fo the Z. vortec fo K-5
Transmission: 4L60E=Z junkR4=K-5
Axle/Gears: 3.43=Z / 3.73=Blazer
Re: [90-91] - How does needles light up on instrument panel?
so you have ordered the reverse glow gauges? do they work like on the website i need a new instrument panel and these are cheaper. so i was wondering how they worked/looked. i tried doing the same thing by replacing all of the bulbs with blue.
Old Jun 11, 2007 | 12:14 PM
nice car how do you post your pics?
Ghettobird52
Jul 5, 2024 11:18 PM
Jeremys87
Jul 14, 2022 09:08 PM
Vintageracer
Jan 10, 2020 05:33 PM
Omega
Aug 10, 2015 12:46 PM
