crime car?
Old Jun 24, 2007 | 07:37 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
crime car?
i started wet sanding my car(dollar store primer) only to reveal it had a perfect midnight blue met. paint job underneath it. i starting to think it was used in a crime and they primered it up like this to hide it .cuz no body in thier right mind would of did this. i wondered why it was hid in the back of a barn.
Old Jun 24, 2007 | 08:40 AM
rideon1200's Avatar
On Probation
Car: 2002 Formula
Engine: 5.7 LS1
Re: crime car?
Are you going to be able to save the paint job. Sound like a winner there.
Old Jun 24, 2007 | 08:53 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
Re: crime car?
i don't know.i'm hoping i can find someway to the primer off ,and maybe just get away w/ just re clear coating.
Old Jun 24, 2007 | 09:25 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: crime car?
Haha, you've been playing too much GTA.
Old Jun 24, 2007 | 03:39 PM
ntomsheck's Avatar
Car: 1989 GTA
Engine: 350TPI w/ Speed Density
Axle/Gears: Borg warner 3.27
Re: crime car?
try brake fluid. That'll take paint right off, but it doesn't do it super fast. You might get away with just eating the primer off and maybe some of the clear coat if you do it right.
Old Jun 24, 2007 | 09:42 PM
86irocterror's Avatar
Re: crime car?
primer over a good clear i would try wd40 and see if it takes primer off. it wont hurt clear coat
Old Jun 24, 2007 | 09:49 PM
2tonedmaro89's Avatar
Car: '91 RS
Engine: 5.0L gross *** tbi
Re: crime car?
go to ur local automotive store and get aircraft coat remover...spray it on the rag(dont get ur hand it burns like a b****) and wipe it off...i had some primer spraypaint over my sunfade and got some overspray on my paint...came right off
Old Jun 25, 2007 | 06:12 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
Re: crime car?
cool i'll try it out today.
Old Jun 25, 2007 | 09:52 AM
jaysfs's Avatar
Car: 91 z28, 07 trailblazer ss
Engine: lt1lt4 hot cam,ls2
Transmission: t56
Re: crime car?
all those sound really scary,did they actually scuff the paint underneath the primer? wax and grease remover may take that crap primer of and not desrtoy the paint that lies underneath.brake fluid and paint stipper is kinda insane sounding too me. i am sure you guys have tried them with luck but it just sound scary
Old Jun 25, 2007 | 11:44 AM
RocsRose86's Avatar
Car: 1986 Irocz28/04 GMC Yukon
Engine: Ram Jet 350(*TPI*)
Transmission: Turbo 400 w/1500 stall
Re: crime car?
YOU MAY TRY LAQUER THINNER ON THAT CRAPA// PRIMER.
Old Jun 25, 2007 | 11:56 AM
naterman35's Avatar
Car: 89' Camaro RS--
Engine: 305--
Transmission: Automatic
Axle/Gears: 2.73--
Re: crime car?
BRAKE CLEANER!!... not brake fluid... Brake clean... It takes primer off no problem but it doesnt take off clear coat... Use that before you try anythign else. Buy a can from like napa... and use it trust me it works wonderins takign primer off.
Old Jun 25, 2007 | 01:16 PM
87 formy's Avatar
Car: 87 formula
Engine: 5.0 TPI
Re: crime car?
That's what I was going to say, that won't hurt the clear coat.
Old Jun 25, 2007 | 01:56 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: crime car?
How us some pictures please. Looks like an interesting car.
Old Jun 25, 2007 | 02:03 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Re: crime car?
DO NOT DO THIS! It WILL ruin the paint underneath.
Old Jun 25, 2007 | 05:24 PM
Car: '91 RS
Re: crime car?
not if you do it the way i said!!
if you directly spray it on then
but if you spray on the rag then wipe off the primer it works perfect
Old Jun 25, 2007 | 09:37 PM
Azrael91966669's Avatar
Car: 1991 camaro RS
Engine: CharlesOdoryOB
Transmission: 82513892892
Axle/Gears: pbr disc 3.27 nine bolt
Re: crime car?
alot of times when a car is primered its because there is body work somewhere it may have some good paint under it all but ill bet you find the roof or something faded or a body repair
the last owner may have been prepping it for a new paint job
and being its an ohio car ill assume its a rust repair you well end up finding the bad spots sooner or later
you really should go over the car with a magnet 1st
btw you may end up finding that one panel is differant colored then the rest
for example my girlfreinds firebird has a really crappy rattle can red paint job but thats because it has a black hood silver fenders white bumper front and blue rear bumper
but thats the problem getting junk yard body panels pretty rare if you find the correct color
so you end up primering it so you will find the reason why its in primer sooner or later
Old Jun 27, 2007 | 02:03 PM
zeek's Avatar
Car: 1986 firebird trans am
Re: crime car?
the same thing just happened to me 2 weekends ago my car has been in black primer sense iv owned it and i got sick of looking at that so went and bought paint when i started to wetsand the primer it just started to wash off (aparently the kid didnt sand the car before putting the primer on it ) and under the primer was a perfect gun-metal gray paint job if i hadnt already bought the new paint id have kept that paintjob sense it was actualy pretty good.
so moral of this story is just keep wetsanding it
Old Jun 30, 2007 | 02:19 PM
25th327RS's Avatar
Car: 92 Ttop Z28
Engine: Cammed 6.0
Axle/Gears: Built 10 bolt-3.90s w/ PBR discs
Re: crime car?
if the paintjob was scuffed or sanded down before priming, it'll be nearly impossable to remove the primer without wetsanding it all off and praying you dont burn through the clear. if a jacko just bombed some spraybomb primer on the car without doing anything to it, chances are lacquer thinner or a basecoat reducer will take it off. lacquer thinner will almost NEVER hurt a OEM paint thats cured for years, but do be leery of lacquer thinner on re-finished vehicles.
Old Jun 30, 2007 | 05:08 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
Re: crime car?
lacquer thinner shouldn't hurt cured clear coat.
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
