How much paint to buy?
Old Jun 29, 2007 | 06:48 PM
simz28's Avatar
Car: 92 z28, 07 Silverado
Engine: LS1, 5.3
Axle/Gears: 3.73, 3.23
I am looking to buy paint for my 92 camaro and i am not sure how much to buy? This isnt going to be a show winning paint job, I just need enough paint to cover everything. Thanks
Old Jun 29, 2007 | 11:32 PM
dcjredline's Avatar
Car: 1989 Formula 350
Re: How much paint to buy?
What kind of gun. How you gonna paint it? Maybe go to your local paint supply place (If you have one) and ask them.
Spray bombs from an auto store get like 10-13 of them.
Old Jun 30, 2007 | 02:04 PM
25th327RS's Avatar
Car: 92 Ttop Z28
Engine: Cammed 6.0
Axle/Gears: Built 10 bolt-3.90s w/ PBR discs
as dcjredline said, it depends on a few things...if your just doing outside panels, no jambs, no ground effects or anything of the sort, strictly outside sheet metal, a general rule is 4 un-reduced ounces per panel. hoods are big, count those as 2 panels, bumpers waste alot of material when attempting to cover complete in the grille openings, light openings and such so also count those as two. another thing to conisder is color, darck colors obviousely cover way better than silvers or yellows. paint brand is another factor, some companies base-coats cover way better than others, a more expensive paint may be worth buying due to using less material.
Old Jul 1, 2007 | 12:10 AM
TheMutt's Avatar
like that guy said, there are a lot of variable. Paint brand alone can almost double the material needed if you use a cheap brand.
Old Jul 1, 2007 | 12:50 PM
jaysfs's Avatar
Car: 91 z28, 07 trailblazer ss
Engine: lt1lt4 hot cam,ls2
Transmission: t56
i just bought shopline for a car i`m doing a complete on. i bought a gallon of clear and a gallon of black. i also bought the reducer and hardeners for 240 all together. i`d say a gallon clear and a gallon of whatever color. I should have some left over. which that is a kind of nice thing too have.
Street Lethal
Apr 30, 2019 12:14 PM
oscarfromla
Southern California Area
Sep 1, 2015 12:39 PM
porkenstein
Convertibles
Aug 31, 2015 12:54 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
RED85TPI
Brakes
Aug 31, 2015 10:29 AM
