steel t-tops?
Car: 1993 Ford Mustang GT
Engine: 5.0
Transmission: 5speed
Axle/Gears: hell if i know
steel t-tops?
Anybody ever hear of the Glass on the t-tops being replaces with steel or fiberglass? I'm just wondering because in the wintertime it would be kinda cool to have insulation instead of glass for the roof, and it'd be a neat little modification
Re: steel t-tops?
There was a guy a year ago saying he was gonna make fiberglass replacements
Never heard another peep from him
I think its a stupid idea just for the insulation
These cars cool off really fast in the summer and heat up really fast in the winter when you keep the systems working good
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
Re: steel t-tops?
If you are just looking for a bit of insulation get a set of t-top panels. They go underneath the glass and are covered with the same material as the headliner.
-Schultzy
-Schultzy
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Re: steel t-tops?
I use the t top inserts in the summer and winter. I leave them out of the car in the spring and fall. I highly recomend them.
Car: 1989 Trans Am t-top WS6
Engine: 305 tpi
Re: steel t-tops?
yep I agree! the sunshades are the way to go! speaking of such I need a pair hmmmmmmmm
Car: 88 Camaro SC
Engine: 305 TBI
Axle/Gears: Posi
Re: steel t-tops?
Steel t-tops would be so cool simply for the fact that if you drop them they'll never break( might break you toes though)
Axle/Gears: 3.45, 3.27, 3.27
Re: steel t-tops?
I wish this were true. I had a NOS set of Lexan t-tops smashed in-transit. The box was old and the glue joint popped allowing the molded foam to shift leaving the t-tops to flop around unprotected. One has three huge cracks down it. The other has just small (under 1/2" chips and cracks where the metal edges are attached to the t-top.
Lon
Lon
3rdgenparts
May 21, 2016 11:50 PM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
darwinprice
17
Oct 11, 2015 11:51 PM
