Removing the Hatch?
Old Jul 14, 2007 | 03:55 PM
Celticsfan's Avatar
Car: 1985 Trans Am
Transmission: 700-R4
Removing the Hatch?
Ok well my hatch supports are shot, i plan on stopping at the junk yard on monday to pick up a set for $20, but i need to know what tools ill need to remove the supports? i could only find threads pertaining to removing the glass...
Thanks guys
Old Jul 14, 2007 | 04:19 PM
ranone21's Avatar
Car: 1989 Trans Am t-top WS6
Engine: 305 tpi
Re: Removing the Hatch?
I can help somewhat as I have taken many hatches off.. you are just changing struts? You will need a t47 torx bit (the one to take out the seatbelts) and a 8mm socket and it should unbolt,....remember to take off the wires to the defogger grid if you have that in your back glass...
Old Jul 14, 2007 | 04:42 PM
Spiers's Avatar
Yep he's right, just need a large torx bit, not sure of size, and I actually believe those small bolts are 7mm, not 8. But maybe different cars are different. Just take small ratchet and sockets, and torx
Old Jul 14, 2007 | 04:51 PM
Celticsfan's Avatar
Car: 1985 Trans Am
sounds good, thanks guys
Old Jul 14, 2007 | 06:32 PM
OkanaganIroc's Avatar
Car: 1987 Iroc-z
Transmission: Modified T-5 World class
Axle/Gears: 9 bolt borg-warner 3.45
I got two sets out of the yard. Just so I have a set in spare. The hatch it pretty heavy so don't forget a prop-rod or a buddy (that you really trust) to hold the hatch up for you while you remove the struts. I also grab the hardware, weather you need it right then or not.
Old Jul 14, 2007 | 07:06 PM
Celticsfan's Avatar
Car: 1985 Trans Am
ya that thing is a beast, i always have to prop it and am scared its going to give and kill me! haha
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
scottmoyer
Sep 7, 2015 07:06 PM
90formulaVortec
Sep 7, 2015 06:54 PM
2012sergen11
Interior Parts Wanted
Sep 7, 2015 11:37 AM
