Door Key.
Old Jul 14, 2007 | 05:00 PM
naterman35's Avatar
Car: 89' Camaro RS--
Engine: 305--
Transmission: Automatic
Axle/Gears: 2.73--
Door Key.
Alright... so when i go the ol Camaro.. No door keys. Ignition and t-top i have. But no door. I was told that if you take the vin to the dealer they can get you one made for the car... Is this true?. Just a quick little question that i needed some help with.
Old Jul 14, 2007 | 05:17 PM
camaro430sut's Avatar
Car: 89 Camaro/ 02 GC Overland
Engine: 355 V8/ 4.7 HO V8
Transmission: T5/ 545RE
Axle/Gears: 10 Bolt 3.73/ Dana 30, Dana 44 3.73
Re: Door Key.
It is true the dealer can cut you a key with the vin. The problem is the car is so old your vin info may no longer be on file. i forget how long GM keeps that kinda info around for. You could try tho, cant hurt right. You say you have a key for the t tops. Have you tried it in the door, they should be the same key unless someone replaced your tops, or lock cylinders. Hope that helps a lil
Matt
Old Jul 14, 2007 | 05:32 PM
88camarosc350's Avatar
Car: 88 Firebird formula 350
Engine: Tpi 350
Transmission: 700-r4
Re: Door Key.
the dealer only can get keys for 90+, i tried to get the key, but they told me i couldnt cause my cars too old.im just replacing the door cylinders considering they are 19 years old in my case.you can get a lock smith to make new keys i think .
Old Jul 15, 2007 | 08:41 PM
naterman35's Avatar
Engine: 305--
Axle/Gears: 2.73--
Re: Door Key.
Well that sucks. I geuss ill look into getting new door locks or something. I've been told that they are the original t-tops... Butttt... I realy don't think they are. Anyway to find out? And were are people buying there locks from? anyplaces you'd sugjest? Im plannign on gettign a system and dont want it in there with out locks.
Old Jul 21, 2007 | 03:03 AM
ATCharming's Avatar
Car: 2000 SS
Transmission: a4
Re: Door Key.
if i were u, id just try to go to the dealer. every dealer may be different, who knows. its worth a shot
i got a 92, went to the dealer and it took a few minutes out of my life, plus less than ten dollars i think.
ignition key was like $40 tho...
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
meeklay812
Oct 1, 2015 03:46 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
Eric-86sc
Sep 28, 2015 11:37 AM
Gunsbee
Sep 7, 2015 07:10 PM
