Hatch lock replacement
Old Jul 16, 2007 | 11:31 AM
kzelisko's Avatar
Well, the previous owner broke his key off in the door of my car, so I had to get new locks. I was trying to put the one for the hatch in, and I couldn't for the life of me figure out how to remove the cable assembly from the back of the lock. If you know the trick to doing this without breaking the pull-down motor(as mine actually works), I would be greatly appreciative of such a gesture.
Old Jul 16, 2007 | 11:50 AM
oxiderush's Avatar
Car: 90 firebird
Engine: 350 5.7L
Transmission: Th-400 w/ Manual valve body
Axle/Gears: 4.10 Richmond gears
Re: Hatch lock replacement
It's in here somewhere, just search. I had to do it before, and it was suprisingly easy after i knew how. It was like a few months ago so i cant remember the details.
Old Jul 17, 2007 | 12:27 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
There is a molded tang that fits into a groove on the OD of the lock cylinder. Use a flat-blade screwdriver to pry between the lock cylinder and the ID of the off-white plastic attachent that is on the end of the cable. Once you have one side free work on the other side. Once both sides are free it will slide off the end of the lock cylinder.
Lon
Old Jul 18, 2007 | 12:46 AM
kzelisko's Avatar
Well, whether this is the correct way or not, I just pryed on it until it came off. Probably incorrect, I in no way incourage this method unless it is true. But thanks to all.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
madsv1000
Aug 20, 2015 06:45 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
