front bumper spider cracks
Old Jul 23, 2007 | 01:25 PM
rv1890's Avatar
Car: 87 Iroc-Z
Engine: 5.7 350 TPI
Transmission: stage2 700r4
Axle/Gears: 2.73 for now
Im looking a replacement front bumper for my camaro. I found a couple decent ones at the local salvage yard, but they both have one thing wrong with them. They have those hairline spider cracks pretty much on the paint layer of the bumper. They are spread evenly along the bumper. I think this is caused from the sun, and I see it a lot on bumpers that have been in the sun. Is this something that can be lightly hand sanded and then primered???
Old Jul 23, 2007 | 08:02 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
Re: front bumper spider cracks
Usually those spider cracks are from someone hitting something; nothing a little paint can't fix. But if you're looking for something that matches your paint, that's a different story....
Old Jul 23, 2007 | 08:58 PM
irockid86's Avatar
Car: 88 iroc camaro
Engine: jasper 350, l98
Transmission: 700R4, corvette servo, shift kit.
Axle/Gears: stock
i am no body expert but from what i have seen, the paint cracks when the plastic is bent because the paint is not as flexible. i would guess that you would have to remove the chiped and cracked paint
Old Jul 23, 2007 | 09:52 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
lightly sand the cracks, then respray with primer (dont forget the flex additive). I believe spider cracks are caused by the sun, Ive never heard of them being from hitting something though. I actually used a palm sander on the spider cracks on my car, just dont use too much speed or force, and it shouldn't hurt the bumper.
Old Jul 24, 2007 | 09:35 PM
rv1890's Avatar
Car: 87 Iroc-Z
Engine: 5.7 350 TPI
what grit do u think i should initially sand with??
Old Jul 24, 2007 | 09:44 PM
RoyalRide_z28's Avatar
Car: 83 camaro Z-28
Engine: 350 4 bolt
Transmission: Th 350
it will have to be stripped down to the bare plastic, or they will come back. clean throughly , strip 180 grit on a Da, spray with adhesion promoter, prime with flex additive in primer.
I just did mine for my full paint job.... it IS a pain in the ***.
1992 Trans Am
May 10, 2023 07:19 PM
mikey8494
Aug 22, 2015 07:57 PM
Wylecoyote08
Aug 22, 2015 01:58 AM
LittleFranks
Aug 20, 2015 03:55 PM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
