Body filler gas
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Body filler gas
I know body filler 'air dries' but I'm having an issue.
The car was painted, sealed with 2k, and shot with bc/cc. In certain spots the paint is lifting, blistering in the sun. I'm curious if the problem is gasses escaping from the body filler. Do you guys bake the filled parts before sealing?
I know the other possibility is solvent pops because of layering coats too quickly and not adhearing to flash time.
-- Joe
-- Joe
Car: '92 firebird
Engine: 305 tbi
Transmission: 700 r4
Axle/Gears: 10 bolt 3.42 gears with eaton posi
Re: Body filler gas
sounds to me like a paint issue. i worked at a body and custom car shop and we never baked the areas with filler on them.
Car: 89 RS camaro
Engine: 454 swap in progress
Transmission: th400
Axle/Gears: 4.11
Re: Body filler gas
yea i agree with red92bird at school we never baked just parts with bondo on them. i also think its somekind of adhesion problem.
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
Re: Body filler gas
Did you have the car with body filler showing outside on a wet day, with high humidity?
Car: 83 camaro Z-28
Engine: 350 4 bolt
Transmission: Th 350
Re: Body filler gas
Definatly is a Paint problem .. I bake stuff with bondo on it all day with no problems ..(even on plastic bumpers)
Sounds like a few things
the metal was not properly prepared.
poor quality primer ( was it a name brand PPG , Dupont, Spies ... ectt..? )
incorrect primer mixture / incorrect flash time.
primer not intended for bare metal.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: Body filler gas
It was sealed with sherwin-williams 2k 'dimensions' sealer (dM 416 I think). Then shot with sherwin-williams 'dimensions' basecoat + clearcoat. (I have the formula if you want to see it)
Today myself, the painter, and the sherwin williams rep cut out one of the bubbles. There was no fumes of solvent, no water, It was complete paint to sealer. It revealed the SMC panel - and not in a spot where any repair was done. So it's a problem with the sealer not adhearing to the SMC.
We're still going back and forth, but I think what is going to happen is:
1) we're going to use an epoxy sealer rather than urethane sealer
2) We're going to wash the whole body down again, sand, wash, resand, rewash
One of the two, either sherwin williams, or the painter, or both is eating the job. The already agreed to repaint it - but I want to know why this stuff is bubbling off.
-- Joe
1992 Trans Am
May 10, 2023 07:19 PM
mdtoren
Aug 16, 2015 05:45 PM
