Front Bumper Cover Removal
Old Jul 25, 2007 | 11:40 PM
Titan85's Avatar
Car: 1987 Camaro SC
Engine: 305 LB9
Axle/Gears: 3:42
Well, I am removing the front bumper cover from a 89 camaro and got everything out except for two bolts on the left and right. On the left and right it has three bolts holding it to the fender, then 2 more above those. I can not seem to get to the absolute top bolt on either side. It is right in front of the horns and holds the headlights in. Is there any special way of getting to it? Thanks
Old Jul 26, 2007 | 12:38 AM
CYARS92's Avatar
Car: 92 Camaro RS, 72 Camaro SS
Engine: 305TBI, til it pukes
Re: Front Bumper Cover Removal
Remove the inner fender well, (easy) get a long extension and have at it.
Old Jul 26, 2007 | 08:58 AM
Titan85's Avatar
Car: 1987 Camaro SC
Engine: 305 LB9
Axle/Gears: 3:42
Thanks for the info, I'll try it today and let you know how it works out
Old Jul 26, 2007 | 10:26 AM
UDAMON's Avatar
Car: Mazda Protege5
or try getting it from the engine bay. theres a hole on each side that you should be able to reach in and get them.
Old Jul 29, 2007 | 01:53 PM
Gangstajpimpin's Avatar
Car: 25th Anniversary Camaro RS (1992)
Engine: 3.1 V6
while this topic is going....
what size socket do you use? im a little lazy atm...its my birthday so i have a reason! haha
Old Jul 29, 2007 | 01:58 PM
Azrael91966669's Avatar
Car: 1991 camaro RS
Engine: CharlesOdoryOB
Transmission: 82513892892
Axle/Gears: pbr disc 3.27 nine bolt
the top ones are 10 i believe the rest are 11 or 12 or i think i used a 1/2 for the other ones
Old Jul 29, 2007 | 03:46 PM
Titan85's Avatar
Car: 1987 Camaro SC
Engine: 305 LB9
Axle/Gears: 3:42
Yeah, the top are 10 and the rest are 11mm.
Haven't got it off yet, been busy with work : /
Old Jul 29, 2007 | 04:46 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
I removed the horn for easier access
Old Aug 3, 2007 | 08:17 AM
Titan85's Avatar
Car: 1987 Camaro SC
Engine: 305 LB9
Axle/Gears: 3:42
I finally got around to working on it. I actually ended up just getting it from the engine bay, just had to make lots of small turns. Thanks for the help
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
LittleFranks
Aug 20, 2015 03:55 PM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
