fender problem
Old Aug 7, 2007 | 06:08 PM
mikeny's Avatar
Car: 1988 Firebird
Engine: 5.0L V8 305
Transmission: automatic
fender problem
has anyone taken off the passengers side front fender off of thier 3rd gen fbody?
i am in the process of fixing my'88 firebird and have all the bolts and screws off of the fender but there is 2 things that are holding it together. the antenna and a bolt underneath the car that i cant seem to get loose. but my biggest problem is the anntena. i dont have a power antenna. and i unscrewed the actual antenna but there's still a part of it that i cant take off. i tred to pry it off with a screw driver but no luck. also underneath the car right by the mud flap there's a bolt under the car i cant seem to take off either. i attached pics of both problems i'm having. anything will help. thanks.
Attached Thumbnails fender problem-000_0312.jpg   fender problem-000_0313.jpg   fender problem-000_0325.jpg
Old Aug 7, 2007 | 06:15 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
Re: fender problem
antenna part should twist off, should have 4 teeth notches you can use to turn it and twist it off.
and the reson you cant get the bottom botl off is because that car either hit a high rock or high sewer main going through a road under contrustion and bent the whole piece up into the body. my car had that too.
take soem heavy duty pliers and bend it back down then you can gert to the head of the bolt and take it out.
morrow
Jan 13, 2024 12:29 PM
customblackbird
Aug 15, 2021 10:16 PM
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
