Where to get rear piece?
Old Aug 11, 2007 | 11:27 AM
ken3983's Avatar
Car: 1989 Firebird Formula 350
Axle/Gears: 9 Bolt Borg Warner 3.27 gears
I'm looking for the rear piece on the rear hatch. It's the flat metal extension where the spoiler connects to. It seems the spoiler has come away from the studs and I can't get the nuts off the other side to take the studs out. If I could get the nuts loose, I can JB Weld the studs back in the spoiler.
Ken
Old Aug 11, 2007 | 11:31 AM
MarkAJ86's Avatar
Engine: 305tbi
Re: Where to get rear piece?
If you need it just check the junkyard
Old Aug 11, 2007 | 11:56 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Perhaps I don't understand. Why can't you remove the nuts?
JamesC
Old Aug 11, 2007 | 03:26 PM
ken3983's Avatar
After the spoiler came off, the studs were exposed. I tried to hold the studs with channel locks and put a socket on the nuts. No go. They would'nt budge at all. I don't believe they have ever been taken off. I was thinking about applying heat to the nuts. However, I have found a rear spoiler along with the studs for 31 bucks. NOS. I might get that if I can remove the old studs first.
Ken
Old Aug 11, 2007 | 04:21 PM
TheMutt's Avatar
Get a set of vice grips and get those bishes off. It would be easier than finding, painting, and changing the hatch. If all else fails, just grind or saw or cut the studs off.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
AmorgetRS
Convertibles
Aug 31, 2015 11:55 AM
