Install lift off hood, me or a bodyshop?
Old Aug 13, 2007 | 08:01 PM
OneBeast88's Avatar
Car: 1988 Camaro Sport Coupe
Engine: L03 305 TBI
Transmission: Five Speed
Axle/Gears: 3.08
I am going to order a 3" harwood lift off cowl hood on the 1st. As soon as I sell my boat I am going to get the car painted. Should I let the body shop install the hood or should I?
I do not know if I want to go with pins or dzus fasteners. Do you rivet the mounting plates to the car or weld them? How hard is it to get everything to line up?
Thanks.
Old Sep 1, 2007 | 12:03 AM
robbyho21's Avatar
Car: 88 camaro
Engine: 355
Transmission: rebuilt 700-R4
Re: Install lift off hood, me or a bodyshop?
WOW
Old Sep 1, 2007 | 01:17 AM
sp63
Guest
Posts: n/a
tough decision. the dzuz will "hold" the hold down far better than pins ever will. they just dont look as "good". as far as the mounting tabs for the dzuz. id pay someone to do that hole shindig. its a pretty tedious and precise process. id let them handle it and get it done right. i cant remember off the top of my head but i think its 8 length wise and 4 laterally.
Old Sep 1, 2007 | 03:35 AM
WheelsUp84z's Avatar
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
its super easy to do both. If you go with the Pin route, put four across the front and 2 in the rear, possibly a support for the cowl as well. if you go for the dzuz, all you have to do is either rivet or tach the plates to the fenders, set the hood on tip, mark the location of the plates, drill holes for the fasteners, mount em and thats it. Just looks more intimidating.
Old Sep 3, 2007 | 12:44 AM
jay_d's Avatar
Car: 84 z28
Engine: 355
Transmission: TH350
Axle/Gears: one wheel peel
as far as i know the hood pins would work.....just alot of work getting everything lined up so it dont look like the hood is setting on top of the fender bolts......let me know how it goes....im planning on putting the same hood on my car..........JEGS $285
Old Sep 3, 2007 | 09:27 AM
VonDoering's Avatar
Car: 92 camaro RS
Engine: 305tbi
I had a prelude I put a lift off hood on. All I did was measure the same distance from the fender to the point on the rad support. Drilled those two holes and installed the pin shafts. I then took some black paint(any color) and put a glob on either pin. Then slowly put the hood in place and press down lightly. The pins will mark their spots and you drill there. Same thing for the rear.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
bryan623
Aug 10, 2015 11:33 AM
