Question about T-Tops
Old Aug 21, 2007 | 09:03 PM
Big Dave's Avatar
Car: 1992 RS Heritage
Transmission: TCI 700r4
I tried a search, but can't find an answer to my question, so here goes. I have a 1992 RS that I am restoring, and the Lexan t-tops are in pretty nasty shape. Rusted around the edges, spider-webbed, and lots of small cracks. T-tops are pretty much a dime a dozen on eBay, at junkyards, etc... I know all years will physically fit, except the locking mechanism. My questions is can older style tops be made to work with my 92?
I appreciate any help
Dave
Old Aug 22, 2007 | 01:02 AM
83camaroMN's Avatar
Car: 1998 Mustang
Engine: 3.8L V6
Transmission: Automatic with overdrive
Axle/Gears: 2.73:1 axle ratio
I think the older ones have the latch to lock it in place while the newer ones have the pin style so if you get the right style I think it will fit but I am not 100% sure.
Old Aug 22, 2007 | 01:34 AM
MarkAJ86's Avatar
Engine: 305tbi
Re: Question about T-Tops
From what I understand you have to have the ones from 91-92, because the latches are different
Old Aug 22, 2007 | 02:15 AM
TheScaryOne's Avatar
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
I believe the difference in pin-style was the large pin and small pin, and I believe large pin is just a rubber sleeve over the small pin. I dunno. I'm about to restore (partially) my T's, and I currently have two sets sitting next to me and one set stuck on the car.
Old Aug 22, 2007 | 08:40 AM
Elthesh's Avatar
Car: 1991 Pontiac Trans Am
Yours will be the larger pin style like mine. If you have to use one with a small pin or latch, you'll also need to replace the mechanism on the pillars as well. Altough it's just easier to find the larger pin style. I HAVE used the smaller pin style in a larger pin mechanism. It worked for me just fine, no leaks, etc. So... But you're better off with matching parts.
Old Aug 22, 2007 | 09:07 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Your right - it's just a (plastic) sleeve over the small pin.
If I'm not mistaken the "hook" or "latch" style was used only in the 82-83 cars. After that the small pin was used until sometime around 90. That first "hook" desigin seems to be the rarest of them all. ( Besideds the C&C set-up used through all the years. !)
Not really........ When I bought a set of Lexan T-Tops I also bought the matching pin retainers at both sides of the pillars from the same car. When I was about to swap them I found they were exactly the same. I pulled the glass tops off my 84 and put the LEXAN set on - DONE !
You can use ANY "PIN" style T-Top on any F-body..... Big or small pin. I just sold a set of 84 glass tops to a guy so he could replace his Lexan set on his 92 - no problems. There are differences like the outer chanel on the LEXAN compared to the smooth edged glass and so on, but they will work without changing anything else on the car.
* This excludes the Cars and Concepts aftermarket T-Tops !!!
Old Aug 22, 2007 | 10:11 AM
Big Dave's Avatar
Wow. Thanks for the great information. Let me make sure I got this right. I can use any of the pin style tops on my 92... provided I retrieve the appropriate pillar parts, or find a way to put that plastic sleeve from my tops on the other set? Sounds basic enough.
Old Aug 22, 2007 | 11:36 PM
83camaroMN's Avatar
Car: 1998 Mustang
Engine: 3.8L V6
That sounds about right I have the hook style in my 83.
1Aauto
Sponsored Vendors
Aug 26, 2015 02:14 PM
1Aauto
Sponsored Vendors
Aug 24, 2015 03:40 PM
Penultimo
Camaros Wanted
Aug 20, 2015 08:42 PM
qz6lwp
Aug 20, 2015 08:10 PM
redmaroz
Aug 16, 2015 11:40 PM
