shorter front gfx.
Car: 1992 RS Camaro
Engine: 350 small block V8
Transmission: icky automatic
shorter front gfx.
i have a 1992 rs camaro. does anyone know if there is a shorter front ground fx for it? or even if i could put an older year third gen front bumper on?
Car: 1979 Z28 / 1990 RS
Engine: Matching 350 / 305 TBI
Transmission: Built TH350, 3000 Stall / 700r4
Re: shorter front gfx.
are you wanting to have a smaller front bumper? if u do you could put on a 82-84 z28 front bumper but id stay with stock myself...
Car: 1992 RS Camaro
im just tired of having my bumper torn up every time i hit a speed bump... its just to low to the ground. i was thinking of making it into a z28 clone anyway...
Car: 92 RS, 05 GTO (sold), 10 TL AWD
Engine: 383 HSR w/DSC1
Axle/Gears: Strange S60/3.73
not to sound sarcatic, but either park short or back into parking spots. rear bumper clears just fine. that's what I do.
as for speed bumps, drive crosswise over them. that is the curse of the 3rd gen.
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
what rubs on speed bumps is the lower air dam . sounds like you are scratching the underside of the car . dont remove the air dam or you will have cooling problems . air dams are easy to replace every couple of years if you need to . also very easy to make . learn to love it . it goes with the property .
evilstuie
Feb 28, 2016 03:33 PM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:18 PM
