Better Finish
Old Sep 12, 2007 | 04:19 AM
86WS6's Avatar
From: Great Smoky Mountains, Bryson City North Carolina
Car: 86WS6 30K and 82WS7 24K
Engine: 86:305 TPI, 82: 305 LG4
Transmission: 86:700R4, 82: T200C
Axle/Gears: 86:3:27 9 bolt, 82: 3:23 10 bolt
Better Finish
The original finish on my 86 T/A, (cobalt blue & silver) had yellowed and the clear coat was cracking. It is a California unit with the wonderful water based paint. Had it repainted in the base/clear, same color, and replaced all of the decals with reproductions from Pheonix Graphics. Everything looks OK for a driver, but I notice that under florescent lights there are some dry spots in the clear. The blue is even and nearly blimish free, and the dry spots only show up under bright artifical light. The car looks real good in the sunlight. Can the car be re-clear coated, or should I just start over with the paint? Someone told me that you can clear coat over the decals and make everything look more finished and smooth? I used to paint back in the 70's, and do not know anything about the new paint systems, so I will have to hire it out. The car has 27K miles on it and is very clean. I want to get it ready for some local shows and car events, and I know the judges will zing me on the dry spots in the paint. Thanks in advance. Charles
Old Sep 14, 2007 | 11:52 PM
jay_d's Avatar
Car: 84 z28
Engine: 355
Transmission: TH350
Axle/Gears: one wheel peel
Re: Better Finish
i wouldnt try to paint of the vinal decals..... they aren't flush with the body and the clear would probably run around with creases.....not to mention they might react with the clear & make it crack.....my best advice is to buff with a rubbing compound then with a swirl mark remover.....then buff with a polishing compound
Old Sep 15, 2007 | 02:55 AM
86WS6's Avatar
Re: Better Finish
Thanks for the tips. I had not thought about the vinyl reacting with the clear coat, and that is a good point. I will try to buff it. Charles
SRKLEGIN
Oct 29, 2015 06:38 PM
91 SrS
Oct 7, 2015 04:32 PM
loud91rs
Oct 5, 2015 10:05 PM
James Sutton
Sep 23, 2015 01:56 PM
Linson
Sep 21, 2015 01:08 PM
