Shredding The Pounds
Old Sep 16, 2007 | 09:10 PM
Z2EIGHT's Avatar
Car: '92 Camaro Z28
Transmission: Built 700R4
Axle/Gears: Unknown 9 Bolt Posi, 3.73s
(Mods fill free to move to this to the appropriate Section)
Today I was bored and decided for the heck of it to get rid of some useless junk. I got rid of the Spare Tire, Jack and the nuts and bolts that go with it. It'll prolly bite me in the A$$ later but oh well..
Anyways I was trying to remove that long rod in the trunk that you can pull out to cover your trunk contents, but with tint and louvers I don't need that, How do I remove it?
I was thinking about the AC compressor too since mine is busted but I don't have money for the shorter belt.
-Peace
Old Sep 16, 2007 | 09:23 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Axle/Gears: 3.23 non posi
Re: Shredding The Pounds
The rear hatch cover should just pop out. It is held in place by a round slotted peice on the end. Wouldnt be worth the wieght reduction though. It probably weighs 2 lbs
Old Sep 16, 2007 | 09:28 PM
Stevo's Avatar
Car: Pair of 92 Z28s
Dont hack your car...take it from another fellow fully optioned Z03 Z28 owner...
Been there done that. Guess i should say: Been there doing that.
Old Sep 17, 2007 | 11:58 AM
92camaroz28ss's Avatar
Car: 92 z28
Engine: fast burn 385
Transmission: t56
if you really want to get rid of the hatch cover let me know, i might be interested if it still works and is in good condition
Old Sep 17, 2007 | 12:23 PM
Boogie123's Avatar
Car: 88 Camaro
Transmission: Th350
Axle/Gears: 3.73's
I got my car weighed last night..3460, a little lighter than I figured.
Old Sep 17, 2007 | 01:50 PM
rhamm1320's Avatar
As a rule of thumb, you will reduce your 1/4 et by 0.1 sec per every 100#'s, so keep that in mind when weighing the gain vs hassle. If your car is a daily driver, I would reconsider keeping the spare tire.
Keep you A/C parts, someday you may want them back and it would be much more difficult to gather up the parts from classifieds or wrecking yards.
Old Sep 17, 2007 | 07:49 PM
Z2EIGHT's Avatar
Car: '92 Camaro Z28
During school today I was thinking about the whole weight reduction.
I'm gonna keep it stock, too much hassle and it will look nicer.
Old Sep 17, 2007 | 10:43 PM
ntomsheck's Avatar
Car: 1989 GTA
Engine: 350TPI w/ Speed Density
Axle/Gears: Borg warner 3.27
Go for more subtle weight reductions. Tubular K member, coil overs, tubular A arms, aluminum drive shaft, light(er) weight wheels, aluminum underdrive pulleys, ...LS1 (that'll drop 150lbs and take away about a second or two )
Weight reduction isn't really worth it if it's a street car. With weight reduction, you always have to give up something. Either creature comforts, or lots of cash. Sometimes safety is given up, or driveability. Switching to a tubular K-member leaves your oil pan more exposed, removing the front bumper support (100lbs off the front) is almost certain car destruction in the event of a front end collision. Instead of putting your money into lightweight parts or paying hospital bills, why not put it into go-fast products. Save up for a nice set of AFR heads
Old Sep 17, 2007 | 10:53 PM
Stevo's Avatar
Sorry try 26 pounds for the front bumper support. You can remove that or replace it with an alum bumper support which will save you 5-10 pounds.
Old Sep 18, 2007 | 02:18 PM
Z2EIGHT's Avatar
Car: '92 Camaro Z28
Yea Yall right...
Old Sep 18, 2007 | 02:59 PM
ntomsheck's Avatar
Car: 1989 GTA
That's It? my bad haha. Oh well, I was close. Only off by a multiple of four
beltran89
Theoretical and Street Racing
46
Oct 7, 2015 07:36 PM
gord327
Sep 29, 2015 10:18 PM
tgp1990
Sep 4, 2015 06:24 AM
twest2k2
Aug 24, 2015 11:26 AM
Birmass
Oct 24, 2000 08:11 AM
