painting my car
Old Sep 17, 2007 | 01:17 AM
spicrick's Avatar
painting my car
i am gonna sand off all the old paint and paint my car flat black...instead of actually using real paint im just gonna use primer and call it good...but i was wondering if it would work on my plastic front bumber
Old Sep 17, 2007 | 01:43 PM
rhamm1320's Avatar
Re: painting my car
Should work as long as the surface and any loose chips of paint are sanded down. The good thing with primer is if a area chips away, primer back on top of it
My personal opinion, but white primer is the easiest to get a even coat with and looks a little better in the end. The darker the color, the more you can see your spray pattern and tell it came from a can.
Old Sep 17, 2007 | 02:43 PM
strokermotor91's Avatar
Car: 91 Camaro RS
Engine: Small Block
Transmission: TH350 w/ 3000 stall convertor
Axle/Gears: 3.73 w/ powertrax locker
Re: painting my car
The bad thing with primer is, water eats right through it. You'll start to see rust forming on top of the primer. Unless you have a good coat of paint on there, the metal will be in danger. TRUST ME I KNOW!
Old Sep 17, 2007 | 02:54 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
Re: painting my car
If he's just primering a car, I think the primer cracking on the bumper and looking like crap is going to be the least of his concerns. The only primer that will really hold up to the weather is auto body grade epoxy. It is not cheap and must be sprayed through a gun. Anything else is going to be a sponge, like stroker said.
Old Sep 17, 2007 | 08:56 PM
Titan85's Avatar
Car: 1987 Camaro SC
Engine: 305 LB9
Axle/Gears: 3:42
Re: painting my car
O_o...why would you do that? What is there to gain?
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
kah992
Aug 19, 2015 02:55 PM
ElPaleterro85
Aug 13, 2015 03:49 PM
Exxon Limited
Aug 9, 2015 08:13 PM
kyle5647
Aug 7, 2015 03:08 PM
