Ttop Seal Strip Replacement
Old Sep 19, 2007 | 07:12 AM
Rikj's Avatar
Car: 86 Camaro
Engine: 2.8L V6
Transmission: 5 Spd
I found and ordered these parts (10198352/3 from Gmpartsdirect), but removing the old ones and putting these in appears to be a bit more involved than I originally suspected once I took the covers off the glass panels.
I did a search in the forum, but the related threads were mostly a few years old, and the link to the instructions on Deadbird.org now brings me to a site to exclude birds from my attic rather than any help on my Camaro =)
Anyone have a good link to a set of instructions involving the Ttop weatherstrip (on the glass panel itself, not the body) and the underlying seal strip?
Old Sep 19, 2007 | 05:21 PM
CreepingDeath94's Avatar
Car: '87 Trans-Am
Engine: LB9 (305 TPI)
Axle/Gears: 3.42 or 3.73..figuring it out still
Re: Ttop Seal Strip Replacement
This sticky was floating around a while back. Not sure why it was more difficult to locate this time, but here it is. Hope it helps.
Old Sep 19, 2007 | 07:58 PM
Rikj's Avatar
Car: 86 Camaro
Engine: 2.8L V6
Transmission: 5 Spd
Strangely, even though I didn't see a link in your reply, I somehow found the instructions here afterwards: https://www.thirdgen.org/forums/body...-number-t.html
One question about them if anyone knows. It specifically says to discard the retainers once you remove them. Is that simply because the instructions came with a new kit containing new retainers, and are they actually able to be salvaged once removed and reinstalled on top of the new seal strip? Or is it because the process of removing them makes them unusable for some reason?
I ask because my retainer and weatherstrip on the glass panels is fine, and I only ordered the seal strip as they were torn and warped on both sides.
Thanks.
Old Sep 20, 2007 | 04:58 PM
Car: '87 Trans-Am
Yea, sorry about that. Guess I didn't paste the link to my reply :-p Anyway, glad you found one that helps...unfortunately I don't know what to do with the retainers...I have never actually done this repair yet.
Old Sep 20, 2007 | 11:01 PM
Guro 305's Avatar
Car: 1986 Pontiac Firebird S/E
Engine: 305 carb'd V8
Transmission: 4-speed auto
Axle/Gears: Stock
While we're at it, the metal strip on my t-tops is looking like crap. I want to replace them with something decent.
Ya know that little piece of metal held on with some phillips screws in the middle. They seem impossible to take off. It should be as easy as taking the screws out and pulling them off right. Is it that those suckers are stuck on there real good after 21 years?
Old Sep 21, 2007 | 07:00 AM
Rikj's Avatar
Car: 86 Camaro
Engine: 2.8L V6
Transmission: 5 Spd
https://www.thirdgen.org/forums/body...nter-ttop.html
That's a thread on the same subject. Doesn't sound too hard to get it out if you're careful with the weatherstripping. It's actually one piece with like 10 screws holding it in (6 visible and 4 covered by weatherstripping).
The part number is 10219403 and it was about $150 on gmpartsdirect.com if I remember correctly. (That's for 86-92. I think it was a different part number for 82-85) That is of course if you had to go the route of ordering a new one if you couldn't find a used one, or one in a junkyard somewhere.
Old Sep 22, 2007 | 11:55 PM
Guro 305's Avatar
Axle/Gears: Stock
Thanks buddy! I'll find some. I find lots of thirdgen parts in junkyards all over So Fla. I find thirdgen parts around here sometimes like flies find s#!t!
1992 Trans Am
May 10, 2023 07:19 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
1nastygta
Aug 8, 2015 07:38 PM
Leggman1
Aug 6, 2015 04:15 AM
