window motor
Old Sep 22, 2007 | 10:57 AM
joecoleman79's Avatar
Car: 1988 Camaro IROC-Z
Engine: 383 Stroker
Transmission: TH400
window motor
So my drivers side power window will only go down about a quarter of the way, but I hear the motor continue to try to take it down. And when I roll it up it makes a grinding sound when the window reaches the top. Anyone know if this is the motor or something else? I originally thought the motor, but the fact that it stops at a specific point and once to keep going up makes me wonder. Thanks in advance!
Old Sep 22, 2007 | 06:00 PM
fbird92's Avatar
Car: '92 firebird
Engine: 305 HO
Transmission: 700R4 TCI performance
Axle/Gears: 10 bolt disc brake 3:42 slp auburn
Re: window motor
sounds to me that you have a bad window regulater. only one way to find out and that is to take the door panel off and check out to see what everything is doing
Old Sep 23, 2007 | 12:07 AM
hydrolic144's Avatar
Car: 1987 GTA Trans Am
Axle/Gears: Borg Warner 9-Bolt 3.27
Re: window motor
My passenger side window is doing the same exact thing. I have my door panel off, I can see the motor and the track, but that's about it. What am I looking for?
Old Sep 23, 2007 | 01:09 PM
fbird92's Avatar
Car: '92 firebird
Engine: 305 HO
Re: window motor
have someone move that window up and down. Look to see if you can see where it is binding or making noise. make sure your regulator moves freely
1992 Trans Am
May 10, 2023 07:19 PM
evan555222
Sep 20, 2016 02:51 AM
pfsteichen
Feb 9, 2016 06:59 PM
neekolzun
Aug 24, 2015 04:59 PM
evan555222
Aug 22, 2015 07:14 PM
