gfx are like warped and dont look right help.
Old Nov 9, 2007 | 12:58 PM
xsupermann69x's Avatar
Car: 1991 Chevy Camaro RS
Engine: V6 3.1L
Transmission: automatic
Alright so as u see in the pics how do i get them to lay flush? they are like bowed out. also my front bumber doesnt seem to be aligned right and has a gap and looks like **** any tips to align better and what to do about my gfx. anyone selling any? let me know
Old Nov 9, 2007 | 02:06 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Re: gfx are like warped and dont look right help.
Was the car in an accident? If it was it could have bent the metal, and therefore bent the mounting holes causing it to flex.
Old Nov 9, 2007 | 05:27 PM
GeeJenn91RSV8's Avatar
Car: 1991 Camaro RS
Transmission: 700 R4
I have the same problem with mine. Just like yours, passenger side only. I think it needs tucked back into the hardware.
Old Nov 9, 2007 | 05:56 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
agreed. the bolts are maybe rusted out, or they need to be tightened.
Old Nov 9, 2007 | 07:29 PM
chevyowner02's Avatar
Car: 1992 camaro
Axle/Gears: 3:73
Mine dose the same thing not as much on the nose. I took the gfx off on the door and I seen nothing holding it out. It mabey due to old age and crappy plastic.
Old Nov 9, 2007 | 08:04 PM
hotrodln's Avatar
Car: 84 Trans AM (sold), 87 IROC, 09 C6
Engine: Lt1 in IROC
Transmission: 5 speeds
Axle/Gears: Moser 12 bolt tru tracker 3.42
I had the lower ground effects bowed out on the front of my 84 TA....the only way I could get it to lay flat was to drill holes from behind, and use sheet metal screws to "pull" it flat. it worked for me.....
Old Nov 13, 2007 | 08:59 AM
Raiderfan's Avatar
Car: '92
I have the same problem. If I can fix it i'll let you know how.
Old Nov 13, 2007 | 01:48 PM
Engine: V6 3.1L
yeah for sure let me know personal message me if u do.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
gord327
Oct 3, 2015 01:25 PM
Numbah-1
Oct 2, 2015 08:27 AM
snakeshooter
Sep 7, 2015 11:15 AM
