Anybody Replaced T-Top & Door Weatherstripping?
Old Nov 15, 2007 | 05:51 PM
awadecki's Avatar
Hi--
Has anyone ever replaced their T-Top & Door Weatherstripping on an 82 or similar T/A? I'm looking to get new weatherstrips, but I want to know if I just peel the seals off, or if there's a few tricks to doing this before I pull the old ones off.
Anyone have the GM P/N's for these parts?
Old Nov 15, 2007 | 06:17 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
Re: Anybody Replaced T-Top & Door Weatherstripping?
GM I think discontinued these, but you can get gm quality from Hawks. I did mine, just be ready to find rust under the seals. also the only trick I think I found out was go slow and get the tabs on the weatherstripping under the tabs on the car (for Ttops, thats all I did)
Old Nov 15, 2007 | 06:25 PM
awadecki's Avatar
Are the seals glued on, or are they just pressed in place?
Old Nov 15, 2007 | 06:27 PM
mlaskow86's Avatar
Car: 1989 Trans Am
Engine: 5.0 TPI
Transmission: 5 Speed Manual
Axle/Gears: Stock Rear End
theyre glued down with a black cement-esq thing, make sure u clean the rails real good before putting the new ones in
Old Nov 15, 2007 | 06:30 PM
awadecki's Avatar
Oh, thanks. What should I use to reglue them, and what should I use to get them off? Rubbing alcohol?
Old Nov 15, 2007 | 08:00 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
to glue them down go to your local parts store and get weatherstripping adhesive. to remove the leftover adhesive I used acetone, but first pull the old weatherstripping off by hand.
Old Nov 25, 2007 | 12:00 AM
vasquezmrysvll's Avatar
Car: 1985 California Iroc
Engine: HSR ZZ4 0411 swapped
Axle/Gears: 3.23 posi
TAKE YOUR TIME!
Old Nov 29, 2007 | 04:00 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
Good luck finding weatherstrip adhesive remover at a parts store. I had to go to a Sherwin Williams automotive paint store and pay $20/can for the 3M stuff. At any rate, best advice I can give is make sure you get 100% (and I mean 100%) of the old stuff off.
Old Nov 29, 2007 | 08:07 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
Just a heads up to anybody looking to buy GM weatherstripping. I just bought the GM stuff from my local dealer and paid $119 for one side and $123 for the other side. That was for the TTop weatherstripping. I haven't located any aftermarket companies that provide a quality rubber for $242. Always look to the dealer first to see if the parts are still available and at reasonable prices.
Old Dec 3, 2007 | 04:56 AM
TA In Progress's Avatar
Axle/Gears: 3.27 BW
Just pray that your T-Top center bar isn't rusted out like a lot of cars out there, they can be pricey to find a good one. I know Advance Auto used to sell the T-Top, door, and hatch seals. I bought my door and hatch seals from them, but I found the T-Top seals from someone on here. The price was decent and the quality was good. They were A&M soffseal.
Old Oct 18, 2009 | 06:27 AM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
any updates?
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
86IROC112
Apr 9, 2016 10:20 PM
gta90
Sep 15, 2015 04:00 PM
BlackTopKing
Aug 19, 2015 12:13 PM
