Window Rgulator Problem
Car: 1987 Camaro SC
Engine: 305 LB9
Axle/Gears: 3:42
I hope this is the right spot for this, but I have a power window regulator and for some reason one of the rollers (circular things that go in the track) is not rolling. It seems to be jammed in place. My question is, can I replace this part? Have a look at the picture below if you are not sure which part I am talking about (circled in blue).
Car: basic third gens
Engine: that I like
Transmission: to restore
Axle/Gears: and enjoy
Re: Window Rgulator Problem
I don't think you can replace them without breaking them, I could be wrong though. Have you tried to turn it with a pair of channel-locks or something?
Car: 1987 Camaro SC
Engine: 305 LB9
Axle/Gears: 3:42
I just tried using pliers and I got it to move. I can turn it with my hand now, but its pretty hard. Does it just need grease or something put in it? Thanks
Engine: that I like
Yeah, see if you can pack some grease into it and then rotate it some more. Maybe it will free up.
Car: 86Camaro RS
Engine: 2.8L V6
a small tube of graphite should help free it up and then i would lube all the rest of the parts so you dont have this problem in the future
Car: 1987 Camaro SC
Engine: 305 LB9
Axle/Gears: 3:42
I put some white litheum grease in it and spun it around to work it in. It didn't seem to make much of a difference though. I found another roller that was kinda tight and put some grease in that one and it freed it up nicely.
I think the roller I am having the issue with may have been replaced already because it is black and the rest are gray.
1992 Trans Am
May 10, 2023 07:19 PM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:18 PM
