chassis stiffening
Old Nov 28, 2007 | 07:08 PM
mxcrazed's Avatar
Car: 87 firebird none soon
Engine: None
Transmission: none
Axle/Gears: 2.73 10 bolt
chassis stiffening
how much chassis stiffening do i need if i'm producing 450 hp on a tt setup?
Old Nov 28, 2007 | 07:17 PM
irocz2889's Avatar
Car: 89 iroc z
Engine: tpi
Re: chassis stiffening
you dont NEED any but youll want all of it but first things first subframe connectors than lower control arms
Old Nov 28, 2007 | 08:13 PM
mxcrazed's Avatar
Engine: None
Transmission: none
is it sufficient to box the lower control arms if so what gage metal and and do you have any links to any products that you would recommend?
Old Nov 28, 2007 | 08:23 PM
VenomX-87's Avatar
Car: 1984 Trans-Am WS6
Engine: WAS: 5.0HO, SOON: ZZ383-425HP.
Transmission: 700R4 with shift kit
Im going bolt in SFC's then im welding them in (for just that little bit of extra security), A triangle brace from the front towers to the firewall (duno if it has a name), A wonder bar (steering), Im also thinking about making a brace betwene the top of the 2 rear shockers but I don't know if it will help any.
There is more but i don't have time to list atm.
Old Nov 28, 2007 | 08:24 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
yea, you can just box the control arms. I'd recommend putting in poly bushings, or at least replace the stock rubber ones, no doubt they're completely worn out.
I used 1/8" steel bar, I think 1.5" wide, about 18" long, per rear control
arm. I've got a few pictures, but it's really quite self explanatory.
Old Nov 28, 2007 | 09:23 PM
mxcrazed's Avatar
Engine: None
Transmission: none
i think there should be a sticky on chassis stiffening!
Old Nov 28, 2007 | 10:37 PM
VenomX-87's Avatar
Yeah, like a walkthrough guide on "How to make a 3rd gen handle 500+HP" I bet it would be a very good sticky.
Well since im tearing my car apart and going over every little part I guess I can compile a good list on what im doing (with pics of what I have done) If someone dose not beat me to it.
Old Nov 28, 2007 | 11:34 PM
slow_90firebird's Avatar
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
I would really like to see a sticky with all different brands of SFC's. I know there are plenty of threads, but everybody has something different to say about every brand.
I would like to have all the brands analyzed with the price, how effective they are, and pictures of installation, and connection points.
I was looking at a bunch of different brands, and they all seem to follow different paths under the car. They also all weld or bolt in at different points. Some just seem to stiffen the pinchweld area, while others go from the actual front subframe to the rear subframe. Even some others go from the front subframe to the rear LCA location.
If anyone else is interested, I could start the thread. I would research what I could, and post it up. I have no real experience in owning SFC's I have just been looking. But if i started it, others could add their own setup, pics, and comments.
Old Nov 28, 2007 | 11:47 PM
VAN454's Avatar
Car: 88 GTA
Engine: Ls1
Axle/Gears: 9 bolt 3.27
I'd be interested, sub-frame connecters are then next thing after a brake upgrade for me so I'd love to see a bit of a comparison.
Old Nov 29, 2007 | 12:11 AM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
subframe connectors are great, just make sure the rest of your car is up to snuff before spending the big bucks on aftermarket parts.
the 170 i spent on subframes, and 70 bucks to have them welded in, woulda been much better spent on everything else my car needed before sfcs: springs,shocks, steering components, tune up, blah blah blah.
Old Nov 29, 2007 | 08:40 PM
mxcrazed's Avatar
Engine: None
Transmission: none
hey guys i have been looking into sfc's and i'm planning to do a post on it which will hopefully be stickied but i need to know that else you guys want to know about chassis stiffening sfc's aren't enough what do you guys want to know more about ans because very one seems to be on a budget here anything i do post if it makes it will be based on a qualityrice ratio but i won't be doing any math thanks for the input guys
darwinprice
17
Oct 11, 2015 11:51 PM
aaron7
Sep 30, 2015 09:15 AM
tmork454
Sep 29, 2015 06:33 PM
Chad Speier
Sep 24, 2015 12:32 PM
SG91camaro
Sep 5, 2015 10:27 PM
