Dent on Fender Lip
Car: 1992 Camaro RS
Engine: LO3
Axle/Gears: 3.08
Dent on Fender Lip
Well it finally happened, my first dent
. My aunt backed into my car and scraped the fender lip on the drivers side. Does anyone have any idea what this would cost to repair? She would prefer not to go through our insurance, since we have the same agent
. Supreme Member
Car: 1987 Trans Am
Engine: 355
Transmission: t56
Re: Dent on Fender Lip
pics would help, maybe just pull a good fender off a car at the junk yard, because if u have the stock paint it'll be nearly impossible to match.
sorry to hear about your dent man. well i go to college right now for auto body so maybe i can give you some input. in order to fix your dent, the body shop will have to:
-hammer out the dent
-strip the area down to the bare metal
-apply plastic filler (maybe a couple coats)
-apply polyester putty (maybe a couple coats)
-then prime it
-then spray color
-then spray clear
-then wetsand if needed
that all costs money.
buy a new fender (i just got 2 new in box fenders for 25$ ea) then the body shop has to:
-spray color
-spray clear
which do you think is cheaper? also keep in mind that you are not only paying in materials cost, but you gotta pay these guys by the hour to do it, and buying a new fender is much faster process.
hope this helps man
-then prime it
-then spray color
-then spray clear
-spray color
-spray clear
hope this helps man
Car: 1987 Trans Am
Engine: 355
Transmission: t56
-then prime it
-then spray color
-then spray clear
-spray color
-spray clear
hope this helps man
-then prime it
-then spray color
-then spray clear
-spray color
-spray clear
hope this helps man
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
go to T.J. , S.E. area , get it fixed , watch them , good job , go home .
Car: 85z28
Engine: sbc
Transmission: th400
Axle/Gears: 3.80 gear 35 spline axles
-then prime it
-then spray color
-then spray clear
-spray color
-spray clear
hope this helps man
-then prime it
-then spray color
-then spray clear
-spray color
-spray clear
hope this helps man
Car: 89 Firebird 89 Formula one red one black
Engine: 350, 355
go to a paintless dent repair place like Dent Wizard and have them pull it out and touch up with paint if it is minor.
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
sounds like pictures are a must for this one....
If a dent is on the lip of a fender....it might be pretty hard to get out using PDR. Also....you actually don't have to sand down to bare metal when using todays body fillers....it's actually recommended by ICAR not to sand down to bare metal because your going through thte "E" coat which can lead to rust. Just rough the paint up with 80 on a DA....then you can mud it up....plus..it's much easier to feather out.
Car: 1992 Camaro RS
Engine: LO3
Axle/Gears: 3.08
Well I will try to get some pictures up today to show the damage.
Ideally I would like to just have the dent fixed but it may be more cost effective to buy a new fender.
morrow
Jan 13, 2024 12:29 PM
