HARD QUESTION TO ANSWER POWER ANT. GROMET
Old Dec 9, 2007 | 02:16 PM
NORTHSLIDER's Avatar
Car: 79, 85, 87,91 TRANS AM'S
Engine: 455,305TPI,350TPI,350TPI
Transmission: MUNCIE, T-5, 700R4'S
Axle/Gears: YEP
DOES THE GROMET THAT GOES ON THE FENDER TO THE POWER ANTENNA THE SAME FROM FIREBIRD TO CAMARO?? I THINK IT SCREWS INTO THE TOP OF THE POWER ANTENNA. THANKS
Old Dec 9, 2007 | 03:36 PM
NobleHdwe's Avatar
Re: HARD QUEASTION TO ANSWER POWER ANT. GROMET
I don't know for sure, but I would bet that they are. I'm sure they are the same for most of the GM cars with power antennas.
Old Dec 9, 2007 | 05:21 PM
Axle/Gears: YEP
i looked at my dads trans am and it looks like a 2 piece part?
Old Dec 10, 2007 | 10:37 PM
82CrossFire Z28's Avatar
Car: 82 Camaro Z28, 88 IROC-Z
Engine: 5.0L TBI., 5.7TPI
Transmission: Auto TH200C, 700R4
Axle/Gears: 3.23 posi, ones that rotate!
Re: HARD QUESTION TO ANSWER POWER ANT. GROMET
Yes
The hardware that mounts the power antenna to the fender is two pieces. The center piece, around the antenna, screws into the piece that rests on the fender. You need a special tool to remove the center piece.
I would expect the piece that rests on the fender would be the same for both the Camaro and the Firebird if the fender body shape is the same. Other wise it might be different, to conform to the fender. I also think the center piece would be the same for either car.
My 82 Camaro shop manual refers to the piece on the fender as an adapter and the center piece that screws in as a bezel assembly.
My 82 Camaro factory assembly manual refers to the piece on the fender as the bezel, part #10017246 and the center piece that screws in as the "nut asm", part #10024258.
Dave
Old Dec 10, 2007 | 11:55 PM
Axle/Gears: YEP
i need those 2 piecesif anyone has them let me know
Old Dec 11, 2007 | 09:00 AM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
I might have the two pieces you need, private message me or email me.
MustangBeater20
Oct 29, 2022 09:20 PM
Caspar
Jun 19, 2016 11:19 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
