Can I Use Generic Weatherstripping from Napa/Autozone For My Doors
Old Dec 10, 2007 | 11:41 AM
Blue_Thunder's Avatar
Car: 1986 Chevy Iroc-Z28
Engine: 1989 TPI 350
Axle/Gears: stock 10 bolt with 2.73 gears
Can I use the weatherstripping that Napa, Autozone, and Advanced sells for our cars for my door seals or do I have to buy the gm kit.(way to expensive when I have to get a whole new exhaust too) Same for the t-top seals. I think its my t-tops that are leaking. The water drips from where the t-top headliner is suposed to be right above the rearview mirror.( I don't have the headliner yet). The t-top seals them selves are fine. But what else is up ther that can leak?
Old Dec 10, 2007 | 06:00 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Can I Use Generic Weatherstripping from Napa/Autozone For My Doors
the factory seals have molded ends that are unique to the car, you need to get the proper ones, look around, buying direct from gm will be costly, there are kits from, 1aauto and other companies that are quite affordable
Old Dec 11, 2007 | 11:57 AM
emory 4-4-2's Avatar
try steele rubber products. i got some stuff from them years ago for an old buick and they were great.
Old Dec 15, 2007 | 11:54 AM
theimpaler68's Avatar
Car: 86 T/A & 88 GTA
Engine: 305 LB9 TPI & 350 LO5 TPI
Transmission: Jasper 4L60 x2
Axle/Gears: 2.77/posi LSD & 2.73/posi LSD
look on ebay for them like 86ta said 1aauto has them on ebay the whole set ttops door and hatch area. just search vehicle specific on ebay good prices. steele rubber also on ebay and soft seal as well. happy hunting
Old Dec 17, 2007 | 10:34 AM
fast377's Avatar
Car: 91 Z28
Transmission: t-56
Axle/Gears: 3.73 4th gen 10 bolt
I've used the generic stuff before...once. And that was 1 time too many. It usually fits okay, but it's too thick. It makes the doors hard to shut after you re-adjust to get all the gaps right. GM stuff is way too high. I've heard some good things about soff seal's products. I'm going to try their stuff on my car.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Bradsaundry
Oct 7, 2015 04:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
tattmann
Sep 27, 2015 05:20 PM
