Body Work Question
Car: 86 IROC-Z, 98 Z28
Engine: 370 LSx, LS1
Transmission: T56's
Axle/Gears: 3.73, 3.42
Body Work Question
I starting working on my hood today, and found this. Its a hole for the hood louver, and I was wondering how I should repair it? Any advice or info would be appreciated, thanks.
Car: 1987 Trans Am
Engine: 355
Transmission: t56
Re: Body Work Question
Id say look for a new hood. to fix that would be cut the rust out, make a patch panel, weld it in, grind the welds, bondo over, drill original hole.
Car: basic third gens
Engine: that I like
Transmission: to restore
Axle/Gears: and enjoy
If that's the only bad spot, I wouldn't scrap the hood. If you don't feel like making a patch to weld in, try this: Go to a hardware store a get a thin gauge washer with a similar similar sized hole but is also large enough to cover the severely rusted metal. Then, with the appropriate size hole-saw, weld in the washer and grind down the welds. Viola, no rust and the mount hole is already there to boot
Car: 82 camaro sc
Engine: 355 SBC
Axle/Gears: ford 8.8 3.73
if i were u, i would measure the hole spread from center to center then cut the bad spot out and re weld a new piece in. gring the welds and fill and smooth with bondo-glass (its stronger than bondo) and then drill ur hole. even though its going to be covered by the louver i would get a can of spray primer and spray a generous amout on it......good luck to you
tyler
tyler
Car: 82 Camaro Z28, 88 IROC-Z
Engine: 5.0L TBI., 5.7TPI
Transmission: Auto TH200C, 700R4
Axle/Gears: 3.23 posi, ones that rotate!
You might want to take a look around the local bookstores or talk to your friends and see if you can find a copy of the December 2007 issue of Camaro Performers magazine. It has a very nice tech article detailing the type of repair the others are recommending. (You can also try to bay a back issue from the publisher if you are not in a hurry to fix the hood) Note however that the Jan. 2008 issue is now on the stands.
Sometime in the near future they are supposed to have a web site, but I don't know if they will be posting previous articles.
Dave
Dave
Transmission: T56's
Thanks for all the responses. I had no idea it was this bad. I don't have the resources to do welding, or anything like that. So I was wondering if I could just clean it up as best as I can and possible just slow down the rust, with some type of rust inhibitor, or POR-15? I'm going to be doing the "$50.00 paint job" using Rust-Oleum Gloss Black if it makes a difference. (Im only doing the hood)
Car: 1987 Trans Am
Engine: 355
Transmission: t56
with that rust there, you'll never have the same strength in the hood. I still say your best bet is to buy a new hood, especially since you dont have the resources to weld. if you dont want to do that, sand all that rust off until you get to shiny metal and apply rustoleum. or since its hidden by the louver you could just put rust converter on it, then paint right over it.
Car: 85 z28
Engine: 355ci
Transmission: th400
then use the washer idea.. Member
Car: 84 Z28
Engine: carb 305
I wouldnt recommend the "50 dollar paint job" me and my freind tried it numerious times on his 88 prelude and it never looked good it only looked good from like 20+ feet away. and your driving a camaro!!!! but to eatch his own i guess
Transmission: T56's
Well hopefully it will be fine for the time being, till I get another hood.
I painted a bit where the louvers sit, and so far the "50 dollar paint job" looks very promising. Some people haven't had great success with this paint job, but allot have. You should of seen the hood before and what the Florida sun did to it, it looked hideous. Anything will make it look better than before.
Transmission: T56's
Update:
Well I'm pretty much finished with my hood, just need to polish it. I think it came out pretty good, let me know what you think. I'll get some better pics when the weather clears up, but that probably wont be till Monday or Tuesday.
Terrell351
Jun 13, 2021 01:13 PM
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
