91 92 wrap around wing retrofit question
Old Dec 27, 2007 | 10:31 PM
Rebelhick's Avatar
Car: 86 TA w/ Recaro; 88 Formula 350
Engine: 305 & 355
Transmission: Autos
I was going to buy an aero wing from Hawk's in January but I found a 91 aero wing in good shape for a good price. My 88 Formula originally came with the aerowing but I was wondering how much modification has to be done to retrofit the 91/92 style onto my 88? Will it connect to the window trim the same way and in the same place? How about the deck lid? I know the holes for the 3rd brake light would need to get filled but will it bolt up otherwise? I'm guessing a 91/92 decklid is also a direct bolt in?
Old Dec 27, 2007 | 10:39 PM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Re: 91 92 wrap around wing retrofit question
if you use your decklid your going to have to fill the holes you got and create new ones, how hard that is i'm not sure, i just picked up the entire '91 hatch when i did mine, the deck lid will be a direct swap if you wanted to do that, but i'm not sure if the window trim hooks will work the same.
Old Dec 28, 2007 | 08:56 PM
Steve86TA's Avatar
Car: To many to list
The attach point at the windows are totally different.
92GTA
Apr 9, 2016 07:39 AM
LilHot
Exterior Parts for Sale
20
Apr 1, 2016 04:45 PM
usafirebird
Exterior Parts Wanted
Sep 2, 2015 03:22 PM
LilHot
Aug 19, 2015 10:02 AM
redmaroz
Aug 16, 2015 11:40 PM
