Aftermarket Hood Question
Car: 1988 Pontiac Firebird Trans AM GTA
Engine: Tune-port Injected 6.3L
Transmission: Borg-Warner T56 six-speed
Axle/Gears: Borg/Warner 9-bolt with 3.70:1
I recently upgraded my standard steel Trans AM hood for a fiberglass Ram Air I hood from Hawks Third Gen. When it was installed, the folks doing the install were not able to get their hand up inside to use the nut on the back of the screw that holds down the pop spring. Does anyone know of an alternative way to get the spring installed to the hood instead of to the bumper filler panel? I'd really like to get a spring installed because right now it's a two-person job to open my hood with no spring. Talk about a PITA. Thanks.
Re: Aftermarket Hood Question
Bump...anyone?
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
That hood should have an insert molded into the spring mounting area.
Perhaps yours is broken?or they just forgot to put it in?
If so,maybe just epoxy/fiberglass a nut over the hole so that the screw can thread into that?
I'll get some pics tomorrow.
Iroc8t8
May 4, 2026 08:09 PM
Street Lethal
Apr 30, 2019 12:14 PM
