Door Skin?!?!?!?!
Old Jan 5, 2008 | 06:48 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
Door Skin?!?!?!?!
is it posible to remove just the door skin on the drivers door and replace it, so you dont have to replace the whole door, so that way i can keep my matching VIN's.
My drivers door got raped by a female driver
Old Jan 5, 2008 | 06:58 PM
87 formy's Avatar
Car: 87 formula
Engine: 5.0 TPI
Re: Door Skin?!?!?!?!
Sure,
http://www.parts123.com/parts123/yb....Z5Z5Z50000136b
Old Jan 5, 2008 | 07:10 PM
rustytoy's Avatar
Yes. Happens all the time.
Old Jan 7, 2008 | 03:25 AM
TA In Progress's Avatar
Axle/Gears: 3.27 BW
I believe aftermarket is the only way to get them, I seem to remember hearing that GM has discontinued them.....
Old Jan 7, 2008 | 06:41 AM
rustytoy's Avatar
You know, out of couriosity I am going to check on that today and see if I can still get OEM door skins. I was thinking about skinning my pass. door on my '88.
Old Jan 7, 2008 | 07:20 AM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
Or you could cut out and weld the section w/ the vin tag onto another door. I'd do that before I'd skin a door, which will cost a fortune and is not going to be a 1 day job.
Old Jan 7, 2008 | 10:36 AM
89RS_82Z's Avatar
price and time isnt an huge issue, i want matching vins and it look normal, but im putting a junk yard door on and repainting the car for now just to make it cheaper and faster, but saving my factory OEM door and later on down the road i will re skin it and re install it, anyone know of a cheaper place to get a skin? Classic is $382, would like to spend about $250 for the skin, but if i have to i will pay the $382 from Classic
Old Jan 7, 2008 | 12:14 PM
Car: 2000 BMW M5
Since you are doing this for correctness, I would be asking, who sells the best quality skin. and forget what it costs. A lot of the repro parts for these cars, fenders, hoods, etc, fit TERRIBLE. I have had an aftermarket hood, nose, fenders, etc and they all fit pretty bad. They were all overseas made repro's. You do not want a China/Taiwan stamped piece of sheet metal on a good car, if you can at all help it.
Old Jan 7, 2008 | 03:16 PM
89RS_82Z's Avatar
yea dont want a super cheap deal, but would like to get the best deal possible with good quality, checking into year one now as i type,
Old Jan 7, 2008 | 03:17 PM
89RS_82Z's Avatar
$298 @ Year One
http://www.yearone.com/pco/G_0907/0231.asp
Old Mar 17, 2008 | 03:51 PM
89RS_82Z's Avatar
Called year one and classic today to get one, and the door skin is no longer avalable anyone know of somewhere else i can get one??
Old Mar 17, 2008 | 05:10 PM
Car: 2000 BMW M5
http://www.autobodyspecialt.com/
has full OEM and repro full skins for 82-92 firebirds only. For camaros, they only have a lower 8" repro skin. I don't know what the diff. is between a firebird and camaro door but there must be one if they list them separately.
Old Mar 17, 2008 | 10:08 PM
EH82Z28's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 305 TBI
Transmission: 700-R4
Axle/Gears: 10 Bolt, 2.73 open diff
It might just be because I am an auto body tech, but skinning a door is easy and doesn't take very long at all. You should check the door though and see if the intrusion beams on the inside are bent. If they are you should replace the whole door.
Old Mar 18, 2008 | 03:21 PM
89RS_82Z's Avatar
the lower 8".....that may work.....that is where the damage is.... i dont think the beams are bent, it wasnt hit hard at all
thanks for the website
Old Mar 18, 2008 | 03:24 PM
Car: 2000 BMW M5
I used to live in CT so I would go pick parts up from Auto Body Specialties locally and save tons and tons on shipping. I'm sure that the repro lower patch panel is going to need some body and metal work to get it to fit right, but if you absolutely must keep your door it sounds like your only option.
Or, couldn't you get a donor door and make a patch panel out of it? That way you'd be working with sheet metal that would be of the same quality.
Old Mar 18, 2008 | 03:33 PM
89RS_82Z's Avatar
yea is there a difference in the pontiac door and the camaro door skin
HMMMMMM???????? maybe, sounds like a good idea
Old Mar 18, 2008 | 03:37 PM
Car: 2000 BMW M5
for the cost of whole doors in junkyards near me ($30/each), it's definitely worth a try. I hope you weld, although this sounds like a repair that could be flanged and panel bonded if you had to.
Old Mar 18, 2008 | 03:51 PM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
to my knowledge there was never a difference. I got camaro doors on my firebird right now and other than the color i don't think you could tell the difference 10 feet away or 10 inches away, no visible differences to me. I feel bad now, i've told and read that they are identical...other than body kit holes...is there infact a difference?!
Old Mar 19, 2008 | 07:22 PM
89RS_82Z's Avatar
so im guessing that you can retro fit them to work on a camaro, like i buy the t/a skin and drill the holes out to fit my areo kit??????
Old Mar 19, 2008 | 07:42 PM
84redta's Avatar
thats the only difference to my knowledge between Firebird and Camaro doors, is the ground effect holes. Of which like i said, i got 88 RS doors on my firebird right now, filled in the holes and filled in the mirror holes, and everything matches up and is perfectly smooth, so i'm going to continue to assume they are identical.
Old Mar 19, 2008 | 08:18 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
No matter what skin you get,you'll have to drill the gfx holes.
How bad is the damage on your original?
You already said it was only on the lower (8" area) so I would say to repair the damage while the junkyard piece was paying rent.
Old Mar 20, 2008 | 06:06 PM
89RS_82Z's Avatar
well i need to hurry up and do something, i want it fixed and painted so i can go to some local shows.........im going to go to a j/y and look at a t/a door skin and a camaro and see what i can tell from that
Old Mar 20, 2008 | 06:09 PM
Car: 2000 BMW M5
I have also seen a camaro w/ firebird doors on it. it was a total beater POS so I can't tell you if the door looked correct, but it did fit. It had trans am ground effects on it and the camaro had Z28 ground effects on it. GHETTO. lol. I would just buy the firebird full skin from autobodyspecialt since it is so cheap (what is it, like $135) and then take your old skin off and compare them. Worst case scenario you have to modify the skin or end up using it as a patch panel. For that price its certainly worth a shot.
Old Mar 22, 2008 | 05:31 PM
89RS_82Z's Avatar
yea i totaly agree MARO
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
kkirch15
Sep 30, 2015 04:44 PM
