locks
Car: 1992 Camaro RS
Engine: 305 TBI
locks
ok so like a year or so ago (when my sister ownd the car) some ******* tryed to break into my camaro but wasint able to get in but he dilled a hole under the lock trying to pri the lock out and ever since the key dosent work in that lock so i was wondering what he may have broke and how much would it cost to fix cause its the driver door and i dont like having to go to the passenger side door to unlock the car
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Re: locks
drilled a hole into the door itself or into the lock mechanism itself? You can replace the lock itself or you would have to patch the door and repaint.
Re: locks
sounds like you may need to replace the lock tumbler either way if it isn't working, and then you'll need to either replace the entire door or patch the hole, and spot paint to match the hole that was there.
Car: 1992 Camaro RS
Engine: 305 TBI
Re: locks
well the other door locks still work i just whont to fix the driver door so i dont have to walk around the car to unlock it
Re: locks
You can get new 2 lock cylinders for about 20 bucks from Hawk's, Summit or the local parts guy if it is the lock cylinder and a local locksmith can re-pin to use teh same key if you want. It may be that the jerk bent up the linkage, you might want to look at the linkage inside the door to see if there are some obviously bent and binding parts first, it may be that simple adn checking it is free.
Damon
Sep 26, 2015 04:29 PM
Dragonsys
Sep 25, 2015 03:51 PM
