Camaro Z28-Dent, Rust, Paint
Old Jan 16, 2008 | 10:01 PM
Sdk09x's Avatar
Car: 84 Camaro Z28
Engine: 305 V8 HO
I have a 84 Camaro Z28. It has a dent by the drivers side door. What do you think would be the best way to get that out, and how much do you think it would cost? I also have some rust building up that I want to get rid of, and I was thinking of using some sand paper and sanding it off. Any idea's? And I was also thinking about painting it, but I was wondering what would be the best, least expensive way? I have pics of the dent in another thread.
Old Jan 17, 2008 | 07:57 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
Re: Camaro Z28-Dent, Rust, Paint
I would have to see the dent in order to give some info
as far as the rust do you have a angle grinder-cheap and some rollock 36 grit 2 inch disks
if so grind the rust down and treat it with etch primer- you can get it in a rattle can
Old Jan 20, 2008 | 07:36 AM
irockid86's Avatar
Car: 88 iroc camaro
Engine: jasper 350, l98
Transmission: 700R4, corvette servo, shift kit.
Axle/Gears: stock
every dent is different. you may be able to fix it your self with some time and some simple hand tools and you may have to have part of the body cut out and replaced with some new metal. post a pic and a better disciption if you want some real help. ps knowing how the dent was made will be key also.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Exxon Limited
Aug 9, 2015 08:13 PM
NBrehm
Aug 5, 2015 07:57 PM
