replacing all lock cylinders with no keys
Old Feb 8, 2008 | 11:52 PM
92firebirdLT1's Avatar
i just got my old car back from the police impound but i have no keys for it. i got the doors open but with out the keys i cant pop the hatch to replace all of the locks. i dont have the ignition key either. do you guys have any idea how to pop the hatch with out the key and how to get the ignition lock out with out keys.
sorry if my post is confusing
ps this is my 83 trans am not my 92
Old Feb 9, 2008 | 12:08 AM
driver101's Avatar
Car: 91 rs,1 92 rs,92 b4c/1le
Engine: 5.0tbi,5.7 tune port/5.0tpi
Transmission: 5spdx2 and t56
Axle/Gears: 3.08,3.73,3.42
Re: replacing all lock cylinders with no keys
talk to local gm dealer they should be able to re key the car to the original key code hopefully nothing has been changed
Old Feb 9, 2008 | 12:18 AM
blackandgoldl69's Avatar
Car: 1984 camaro z28
Engine: L69 H.O
Well if your alredy going to repace them you could just pop them with a hammer and a screw driver
Old Feb 9, 2008 | 12:16 PM
the locks are not the original ones so gm probably wont be able to help my main question is about the hatch lock and ignition cause the doors are open
Old Feb 9, 2008 | 07:19 PM
83z28camaro's Avatar
Car: '01 GMC Sierra
Engine: 5.3L
Transmission: 4L60e
Axle/Gears: 3.73 eaton locker
You don't need the key to replace the igniton key. You just have to remove the steering wheel and turn signal switch then pull the screw/pin that holds it in out. As for the hatch if it used the same key as the door you could take one to a lock smith and have a key cut for it. Mike
Old Feb 9, 2008 | 07:56 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
if all the door locks use the same key,it might save you alot of time and agravation to climb over the back seat and pull the rear glove box lock unit out and take it to a locksmith to have a new key made.
For the ign. key you're going to have to remove the steering wheel to remove and replace the lock cylinder.
Old Feb 9, 2008 | 08:00 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
my camaro door key opens a few cars with that style GM blank, try a few out if you got some sitting around or a friends with some GM keys, you may get susprised and only have to make a copy of theirs
Old Feb 9, 2008 | 08:03 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
a locksmith should be able to make you keys for the car for a reasonable price.. I'd call a couple of locksmiths before going through the hassle..
Old Feb 9, 2008 | 08:37 PM
thats too funny,I've heard of this,and I have about 11 or 12 different gm keys and none work on another carLOL!
Old Feb 9, 2008 | 11:16 PM
89RsPower!'s Avatar
you havta wait until the lock cylinders wear out enough..
Old Feb 10, 2008 | 12:04 AM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
you really wanna be cheap...climb in the back...lay on the hump. Take out the 4 screws to the headliner trim above you. Remove the hatch shock bolts inside the car, take out the four bolts to the hatch glass, raise it up about 5-6 inches, to expose the latch loop. Get a saws-all and cut one side of the loop, raise the hatch glass to about a foot or more, you'll be able to tell how car you can go before your going to break something, and by the time you raise it all the way you'll be able to get the saws all in to get the other side of the loop. Make sure you have one or more capable people on the other side of the hatch to catch/hold it against the car until you lower it back into the hinge holes. Done this 3 or 4 times without ruining interior panels, hatch, or car, all you need to do then is replace the latch loop which will cost you less than $5 at a junk yard. Don't ask me how i figured it out but after the first one works i continued to do it to the other two, saved the time and gas of going to a lock smith and i was parting the cars out anyways, but like i said...i didn't ruin a thing. Otherwise i suggest the locksmith. Good luck!
Old Feb 10, 2008 | 01:46 AM
89RsPower!'s Avatar
the lock smith typically comes to you, my friend had a locksmith come out and make keys for his car after he lost em, costed about $60 for 2 door keys and 2 ignition, that was on a non-vats car though..
Old Feb 11, 2008 | 07:52 PM
BadBrains420HR's Avatar
Car: 1982 Firebird S/E
Engine: stock
idk if you have all tried this but on my firebirds ive gone to the back and laid down on the hump ; removerd the plastic piece of the light and pushed the rest of it in and then i got a long screwdriver and if you look into the hole where the light was you'll see a lil square hole just put ur screw driver in there and twist it and it will open
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
