hatch help
Old Feb 14, 2008 | 09:47 PM
rue_69's Avatar
hatch help
I have a 1989 firebird and I'm having trouble getting the hatch open. Here's the problem: I have started disassembling the car and I started with the engine compartment which is totally empty now, no engine or wiring left. Now when I bought the car I did not get a key for the doors, only the ignition - so now that there is no power to the hatch release button on the dash, I cannot figure out how to get the hatch open. Any ideas?
Old Feb 14, 2008 | 10:09 PM
TheScaryOne's Avatar
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
Re: hatch help
You should be able to hit the switch with 12v, or maybe even a 9v battery would do it. I'm not 110% on how the switch works though, so maybe wait for someone else to chime in.
Old Feb 14, 2008 | 10:52 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Re: hatch help
On Firebird the fuse for the hatch solenoid is not in the fuse block, but is in a separate fuse that is attached to the edge of the fuse block. Supply 12v to it and you should be able to pop the hatch.
Lon
Old Feb 15, 2008 | 05:28 PM
rue_69's Avatar
Re: hatch help
does anybody know where that fuse is at specifically?
jrdturbo
Mar 31, 2016 02:58 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
formula00ra
Sep 28, 2015 11:50 AM
