Driver side window adjustments
Old Feb 19, 2008 | 10:53 AM
Rockyd's Avatar
Car: 89Z28 Vert
Engine: 350/tbi
Axle/Gears: 3.27 Posi
my window slides back and fourth and now in and out leaving a gap on the rear of it and was wondering if any of you had this problem and what you did to fix it. i havent opended my door yet to see what it is but is there like a window guild there that i can adjust or is it plastic like mostparts and broke thanks in advance
Old Feb 19, 2008 | 02:48 PM
F41eatsFords's Avatar
Re: Driver side window adjustments
All the assembly that holds your window should be metal. to adjust it, you have to take off the door panel, and there are 2 bolts toward the top, that go through some grooves. my guess is the bolts loosened up over time and caused your problem. once loose, slide them in the grooves to adjust and tighten. that's about all the help i can offer at this point.
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
pfsteichen
Feb 9, 2016 06:59 PM
Street Lethal
Aug 14, 2015 08:25 PM
timonator
Aug 11, 2015 09:56 PM
wruiz
Aug 11, 2015 02:59 PM
