Adjusting Hatch privacy shade/curtain
Old Feb 19, 2008 | 05:13 PM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
I had no clue where to post this, if it needs to be moved please do so for me.
I searched awhile trying to find answers but no one really explained it. from my understand there is a way to tighten the rear roll out shade so that it doesnt sag down when pulled and rolls back in when you close the hatch. So can someone please explain to me how to tighten this? I hear its easy but I toyed with it a while and couldnt figure it out.
Old Feb 19, 2008 | 07:59 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Re: Adjusting Hatch privacy shade/curtain
https://www.thirdgen.org/forums/hist...n-you-fix.html
Old Feb 19, 2008 | 08:31 PM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
So basically I just take the caps off the end of the rod the handles on and roll it? Do i go the way it rolls up or do i go the opposite way it would pull out, but not pull out just wind it around?
Old Feb 19, 2008 | 08:57 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Just follow the instructions, it works
Old Feb 19, 2008 | 09:09 PM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
I beleive it works, im just making sure I understand it
Old Feb 19, 2008 | 11:47 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Read it again SLOWLY, if you want to, fly me to your place and I can do it for you
Old Feb 19, 2008 | 11:48 PM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
HAHA, good one. I understand what to do Just confused which way to turn the roll. I feel so dumb messing with that thing yesterday and this is how you do it, lol
Old Feb 20, 2008 | 12:39 AM
OS3Fleming's Avatar
Car: 1984 Camaro Z28
Engine: 357 SBC
So duke am I suppost to take the end caps that mount to the panels off. And once installed do I rotate it to the rear of the car? Thanks
Old Feb 20, 2008 | 12:50 AM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
My interpretation was to take off the end clips where the two clips on the handle are that connect to the top of the hatch then roll it around and put it back on and pull it out and it should be tighter. Im gonna do it tommarow and will post results
Old Feb 20, 2008 | 01:01 AM
OS3Fleming's Avatar
Engine: 357 SBC
Cool, I will do the same. It going to cold up here so I will have to do it quick.
Old Feb 27, 2008 | 09:44 PM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
That did the trick, thanks!
Old Feb 27, 2008 | 11:06 PM
OS3Fleming's Avatar
Engine: 357 SBC
Mine just clicks while trying to adjust it.
Old Feb 27, 2008 | 11:11 PM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
you may be doing it the wrong way, i did the first time and it got looser. it looks ike you should roll it up in there the way it goes to tighten it, but you go the opposite way of what it looks like it should be. Like if you stand on the passenget side of the car facing it, it should be counter clockwise and it will click each time around, it took mine like 6 turns
Mark_ZZ3
May 24, 2018 01:02 PM
jrdturbo
Mar 31, 2016 02:58 PM
IROCZDAVE (88-L98)
Sep 22, 2015 02:22 PM
