ground effects
Old Feb 28, 2008 | 05:08 PM
91rs5.7tpi's Avatar
Car: 1991 rs camaro
Engine: 5.0
Transmission: t-5
ground effects
how to make them snug j/w because mine jiggle just a bit and it is anooying lol any way to make them tighter ?
Old Feb 28, 2008 | 07:00 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
Re: ground effects
which ones are jiggling? the door ones- take your door panel off, then theres 3 bolts and 2 acorn nuts to tighten.
the rocker ones- take the door jam vent out and reach your arm in, theres a bolt towards the bottom, then take the inner piece (drawing a blank on the name) out of the front fender and reach in there, there should be 2 nuts in there.
Old Feb 28, 2008 | 08:07 PM
91rs5.7tpi's Avatar
Car: 1991 rs camaro
Engine: 5.0
Transmission: t-5
Re: ground effects
the front and the front of the sides
Old Feb 28, 2008 | 08:12 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
Re: ground effects
You'll first have to climb under there,and check the mounting tabs and brackets for damage.
$750 L98
Feb 1, 2025 02:25 PM
Falcon50
Aug 22, 2020 03:26 PM
jovibuilt
Exterior Parts Wanted
Oct 18, 2015 08:12 PM
lewandom
Oct 1, 2015 08:15 AM
Damon
Sep 26, 2015 04:29 PM
