ground effects
Old Feb 24, 2008 | 10:34 AM
bruce lamoureux's Avatar
Car: 1991 firebird formula
Transmission: auto.
Axle/Gears: ?
ground effects
looking for low coast ground effects for my 91 forumla does anybodie out there know where i can get replacement ground effects for my car.tryed looking on ebay but cant tell if they will match up with the rest of the car , so was wondering if there was anyone out there that could help me?
Old Feb 25, 2008 | 09:38 AM
JRods Firebird's Avatar
Car: Different Rides but 1991 Firebird
Engine: V6 3.1 in Bird
Re: ground effects
What are you trying to do. Make your formula look like the 91-92 Firebirds with the ground effects all the way around. If so Ill be listing mine on ebay in a few wks. Due to weather I havent had time to remove them. Im doing a K.I.T.T replica.
Old Feb 25, 2008 | 05:48 PM
Transmission: auto.
Axle/Gears: ?
Re: ground effects
on i have a 91 firebird formula that my step son drove ,that he gave me back with the ground effects all broke up .the front nose is missing chuncks off the bottom ,both door ground effects are missing parts right out of the middle of the door .i figured i need both sides and nose is what i can see now.
Old Feb 25, 2008 | 05:53 PM
brandotron's Avatar
Car: 2002 Camaro z28
Axle/Gears: 2.73 stock, stock, stock
Re: ground effects
Wow, you have a 91 Formy with ground effects? Did you special order it with GFX from the factory, because Formulas typically do not have ground effects. It's not totally unheard of though, my 88 Formy 350 was ordered from the dealer with GFX.
...Oh and smack that kid by the way for busting up your Formy!
Last edited by brandotron; Feb 25, 2008 at 05:55 PM. Reason: Automerged Doublepost
Old Feb 26, 2008 | 11:38 AM
Re: ground effects
well thats what Im trying to figure out. I know they have the nose that the firebirds have in 91-92 but the ground effects I cant picture it on a formula. I seen a 91 formula with no gfx at all. Any picks that you can post would help.
Old Feb 26, 2008 | 07:02 PM
FYRCHKN's Avatar
Car: 1988 SC Convertible
Engine: LT-1
Axle/Gears: 3.23 posi w/PBR's
Re: ground effects
I'm gonna go out on a limb here and say that you're car is just a Firebird, and not a Formula. I have a 91 Firebird and it even says Firebird Formula on the title even though it's just a base bird. There is nothing in the VIN that determines a regular Firebird from a Formula. The VIN will only tell you if it's a Trans Am or Firebird.
The only way to tell if it's a Formula is to check the RPO codes.
I don't think there was ever a 91-92 Formula with GFX.
Old Feb 26, 2008 | 07:03 PM
Transmission: auto.
Axle/Gears: ?
Re: ground effects
would send you a picture but i dont know how to move it from my folder to this web page ,i work with metal not computers,thisis all new to me.yes that is what it looks like ,so its just a firebird eventhow it reads formula?THANKS
Old Feb 26, 2008 | 09:15 PM
FYRCHKN's Avatar
Engine: LT-1
Re: ground effects
If you know how to work with metal then check out this thread: https://www.thirdgen.org/forums/body...ight=gfx+91-92
Mine were busted up when I got the car. They are very expensive pieces IF you can find them.
Old Feb 27, 2008 | 09:37 AM
Re: ground effects
Great info and nice work. Ive had 2 Formula's in the past and both didnt have any gfx. Im going to be removing the gfx off my current 91 bird. I just dont like it, but for what I paid for it and wont feel to bad removing them. Im also going to cut the rear bumper's gfx off and not sure if Im going to keep it like that or get a old trans am bumper. Well then your formula's are rare if I say so myself.
Old Mar 5, 2008 | 07:25 PM
jwduncan's Avatar
Re: ground effects
Any chance would you have a Paper or Electronic Template for the GFX you made from Sheet Metal? I have the same problem with a 91 Stock FB. I located and installed the LF GFX, but have been searching for months for the Right Side. I find everything else aftermarket nearly, but no GFX. Sheet metal seems to me it would be more durable, and if damaged, easier to remake by hand or the local sheet metal shop tech with better skills than I.
Direct email: jwduncan_associates@yahoo.com
Old Mar 12, 2008 | 09:01 PM
Transmission: auto.
Axle/Gears: ?
Re: ground effects
thanks for the responce , so if it was a real formula it would say in the vin no.?like the metal idea might scrap all the plastic and make my own ,the way i think thay should have been.
Old Mar 13, 2008 | 08:41 PM
FYRCHKN's Avatar
Engine: LT-1
Re: ground effects
The VIN only distinguishes between Firebird and T/A. A Formula is basically a "better" Firebird. The only way to tell if it's a Formy is to see if you have a W66 RPO code. If you have a W68 RPO then it's a regular Firebird with the T/A appearance package (GFX).
jwduncan:
I don't have any type of template or drawing of the metal GFX that I made. I just used a broken one that I had for measurements. I made the first one like the broken piece, then just made a mirror image of it.
Old Mar 13, 2008 | 11:23 PM
TheRealBlkBird's Avatar
Car: Pontiacs, Jeeps
Re: ground effects
FYRCHKN: I dont want to hijack this thread so could you please respond in my thread about the 4th gen wings. Thanks in advance.
Old Mar 30, 2008 | 01:14 PM
Transmission: auto.
Axle/Gears: ?
Re: ground effects
you were talking w66&w68 rpo code whhere are thay found ?
Old Mar 30, 2008 | 09:20 PM
FYRCHKN's Avatar
Engine: LT-1
Re: ground effects
On the RPO sticker either in the center console or in the little storage compartment on the driver side rear of the hatch area.
$750 L98
Feb 1, 2025 02:25 PM
Falcon50
Aug 22, 2020 03:26 PM
jovibuilt
Exterior Parts Wanted
Oct 18, 2015 08:12 PM
lewandom
Oct 1, 2015 08:15 AM
Damon
Sep 26, 2015 04:29 PM
