martin senour paints??????
Old Mar 1, 2008 | 08:30 AM
irockid86's Avatar
Car: 88 iroc camaro
Engine: jasper 350, l98
Transmission: 700R4, corvette servo, shift kit.
Axle/Gears: stock
i was told that martin senour makes a great paint for resonable prices. i have a couple paint stores that sell dupont paint and one that sells house of kolor and ppg in my area. i was wondering how the MS compares to all other brands of paint in both price and quality. is the paint good for noobs? and is the price saving at the cost of quality? should i look in to it more or forget the idea of cheap napa paint?
Old Mar 2, 2008 | 01:38 AM
jvontungeln's Avatar
Car: 83 Camaro
Axle/Gears: 342's
Re: martin senour paints??????
Martin Senour is NAPA's name for Sherman Williams. They have some great paint and some crappy stuff just like PPG and the rest. I am planning on using the Cross Fire 5.0 base clear on my car, but I also have woked for NAPA for 13 years. Google Kustom Classics of FT Worth, they are one of my paint customers and they do some very hi end cars.
Old Mar 2, 2008 | 11:53 AM
irockid86's Avatar
Car: 88 iroc camaro
Axle/Gears: stock
i am just looking for a paint that will look nice and last for a long time. this will be my first time shooting paint so i dont need the most expensive or best but a good quality base coat clear coat system seam ideal. do you think i would be better off going with martin senour or is one of the other brands a better choice? can i get the same quality with MS paint as with PPG for a lower cost?
Old Mar 2, 2008 | 12:05 PM
rosco88ta's Avatar
Car: 88 Trans Am
Engine: 355 c.i.
Transmission: 5 spd.
Axle/Gears: 3:42s
If it were me I'd stay away from napa paint. I recently took over management of small shop here, they were using napa paint. I priced a quart of silver paint for my TA Napa wanted 111.00 for the quart and my dupont dealer only wanted 82.50 for the same color. IMO dupont is a better paint than that south of the border Martin Senior stuff. It's really more of a personal preferance thing I guess, but I don't like Martin Senour. It's not as user friendly as dupont is. BTW, you could always use Nason paint, it's duponts cheaper paint line, but the clear won't hold up as long as duponts top line clear. Just my 2 cents.
Old Mar 2, 2008 | 12:07 PM
Car: 83 Camaro
Axle/Gears: 342's
The quality of a paint job is in the preperation. I you can read the directions on the label and have a good store to mix the paint and make recomendations on the correct thinners you will do fine. Cross Fire is a mid level single stage paint. There is a 2 stage Cross Fire version, is is more expensive.
The key to doing a good job is to have someone who you can trust to make the right decisions on which paint to use (thinners, sealers, primer).
Old Mar 2, 2008 | 02:51 PM
irockid86's Avatar
Car: 88 iroc camaro
Axle/Gears: stock
i know the guy at one of the paint shops in my area knows what to use and is very willing to help. he recomended a dupont paint. but i have not been to the local napa. i guess i will just have to see if the guy at napa knows what he is talking about and see if there is a major price differece. thanks guys!!!
Old Mar 3, 2008 | 12:50 AM
jay_d's Avatar
Car: 84 z28
Engine: 355
Transmission: TH350
Axle/Gears: one wheel peel
it really dont matter what kind of base you put down....as long as its the color you like..........ive used pgg deltron and love it......but try some rubber seal and you will love it: sprays better than ppg, lays out slicker, dont run near as bad
Old Mar 3, 2008 | 06:28 PM
irockid86's Avatar
Car: 88 iroc camaro
Axle/Gears: stock
is rubber seal a compeditive brand or is it a type of paint. i want to do a base coat clear coat system. would rubber seal still be possible?
Old Mar 3, 2008 | 10:13 PM
jay_d's Avatar
Car: 84 z28
Engine: 355
Transmission: TH350
its a brand of clear coat......i can get you some specifics if you like
Old Mar 4, 2008 | 02:58 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
The Martin Senour Napa crossfire single stage urethanes and clears are very good quality. It is a big name paint.
Hotrodboba400
Dec 10, 2019 07:07 PM
funkyTA
Sep 10, 2015 06:38 PM
TheExaminer
Sep 6, 2015 11:40 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
