Replacing core support and frame horn(s)?
Old Mar 2, 2008 | 08:28 AM
Buck268's Avatar
I'm kind of looking for some input from you guys here. I've been to a few shops to see what type of prices I'm looking at and they are basically ranging from just over a grand to at least $1500. This is to have the core support cut off at the frame rails and a new one welded up (with new front frame horns); not including the price of parts.
Now basically, I'm hoping somebody here has done this before and can give me a realistic appraisal of the job. Is there any safe "chop points" on the frame rails between the core support and the front suspension? I'm thinking if I got a 'yard car and chopped the front end at the right spot, then chopped mine at the same spot (measure once cut twice, right ) I could weld up some flanges inside the frame and basically have a very large lego set to assemble.
Now, this is not a "I'm doing it tomarow" project, but I want to ascertain the feasibility of this before I put any money into maintanance since I have the front bumper mounted up with a wood 2x6 bracket and the air dam pieces aren't installed.
Old Mar 4, 2008 | 09:08 AM
Buck268's Avatar
Re: Replacing core support and frame horn(s)?
Wow, nobody has done this type of repair before?
Old Mar 4, 2008 | 10:57 AM
2fast4u92z's Avatar
Car: 2 camaros 1 trailblazer SS
Engine: 346twinturbo, 383tpi
Transmission: t56 and 700r4
Axle/Gears: 3:46 4:11
I have seen many people do this. Even the whole front clip(firewall to the front). I would say grand it's to bad. it is a ton of work. If there is just damage on the impack bumper mounts. Then I would just cut that out. If you have front damage and anything else like floor or rear of car. I would look for a roller. Cuz they are cheap<--- at least compared to $1500 for a fix. That money can go to the Paint.
Old Mar 4, 2008 | 11:48 AM
Buck268's Avatar
Frame and everything looks good, except for the left frame horn, which is bashed pretty good into the core support, and I have a little surrounding damage to the core support as well.
I'm thinking I might try to do this when the time comes to replace the car and I can afford to have it down for an extended period...and/or afford to really screw it up. Could be fun!
1992 Trans Am
May 10, 2023 07:19 PM
Terrell351
Jun 13, 2021 01:13 PM
gta90
Sep 15, 2015 04:00 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
TheExaminer
Aug 26, 2015 04:59 PM
