Any bird's here with Hawks 4th gen. wing?
Old Mar 13, 2008 | 11:34 AM
TheRealBlkBird's Avatar
Car: Pontiacs, Jeeps
[img]http://www.hawksthirdgenparts.com/Pr...enSpoiler1.jpg[/img]
Well, that did'nt work so well, guess you'll have to click the link to see it.
Does it mount to the same tabs as the aero wing? What about holes in the rear deck, do they line up, or is this like any other wing where I'll have to re-do everything? I know they make a fiberglass aero wing but Im looking for something different but hopefully without so much work.
Old Mar 13, 2008 | 07:55 PM
85SILVERBULLET1's Avatar
Car: 85 Trans Am
Engine: 383 ci
Transmission: Liberty Geared Tko 600
Axle/Gears: Moser 9" 4.11 gear wavetrac locker
Re: Any bird's here with Hawks 4th gen. wing?
search it! there are lots here.......
Old Mar 13, 2008 | 09:49 PM
Sure are'nt many people answering it if there are lots here. and btw, the search turns up very little good info about the HAWKS 4th gen wing. So unless you have a specific thread to give me then....
They're simple questions, it would take like 2 seconds to answer.
Old Mar 13, 2008 | 10:07 PM
Orinackra's Avatar
Car: 06 SRM M6 GTO, 98 Grand Prix GTP
I would talk to Firebat or Fyrchkn, I think they both have the hawks wing.
Old Mar 13, 2008 | 11:24 PM
Thanks for the heads up.
Old Mar 14, 2008 | 12:40 AM
brandotron's Avatar
Car: 2002 Camaro z28
Axle/Gears: 2.73 stock, stock, stock
Good call, I'd also like to learn about this. My OEM Formy wing is toast!
Old Mar 14, 2008 | 07:12 AM
FYRCHKN's Avatar
Car: 1988 SC Convertible
Engine: LT-1
Axle/Gears: 3.23 posi w/PBR's
Not me. I've got a real 4th gen wing from a 96 T/A.
TIMMYS89GTA has a Hawks wing.
Old Mar 14, 2008 | 11:52 AM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
Yep,I sure do!View my photobucket album for pics.
TheRealBlkBrd,they don't use the same mounting as the org. aerowing.
You have to fill the holes and redrill new ones,and remove the tabs on the edge of the glass.
If you don't want to go through all that hassle,I would rec. just getting the aero fiberglass wing.I believe they are a direct bolt on.
Old Mar 14, 2008 | 12:11 PM
brandotron's Avatar
Man, I could seriously look at your car all day.
Regarding the new holes you had to drill--would I be correct to assume that there are bolt holes under the two back pillars by the center taillight, and also on the side supports right behind the hatch glass? Was it an easy install? Did you have to sand the crap out of it or did it come ready for primer?
That sucks about having to grind the tabs off of your hatch! Does the wing feel secure without them? Thanks again for the info and those awesome pics.
Old Mar 14, 2008 | 12:18 PM
yes,bolts under all 4 pedestals.
It came already primered,and just gave it a 400 grit wetsand before painting.
It was kind of a pain mounting and drilling the new holes and filling the old ones,but not too bad.Worst part was checking,re-checking and then checking again to make sure I had everything even and straight prior to drilling!LOL
Old Mar 14, 2008 | 12:25 PM
brandotron's Avatar
Wow, it comes primered. Awesome. Classic industries has it for like $500! Looks like I'll be getting mine from Hawks.
Hey, this is kinda off topic, but how do you like your new 90's nose? I used to have a 91 and I think I like the looks of that style nose better than my 88, but I hated how it was kinda warped where it meets the hood. Nothing major, it just wasn't a perfect straight line. That seems to be a common ailment among 91's and 92's.
Old Mar 14, 2008 | 12:32 PM
I absolutely LOVE the 91-92 look.
Wouldn't go back to the box look for nothin'.
Just my personal pref. though.
Old Mar 14, 2008 | 12:41 PM
Orinackra's Avatar
hmm, wonder why I thought you did.
Old Mar 14, 2008 | 01:17 PM
brandotron's Avatar
Does anybody on this board have a fourth gen wing with an earlier style nose? Pics?
Old Mar 14, 2008 | 02:14 PM
O.k. how about telling us a little about that install? Was it a royal PITA?
Old Mar 14, 2008 | 03:55 PM
brandotron's Avatar
He already had a thread on the subject a while back. Search around, it's there.
Old Mar 15, 2008 | 04:21 PM
84ls1_transam's Avatar
Car: 1984 Pontiac Trans Am
Engine: LS1 Zex Direct injected
Axle/Gears: 4.88 Moser 9"
I'm getting one from north country fiberglass. I heard they are pretty good.
Old May 31, 2008 | 07:30 PM
This is my wing from north country fiberglass. I think it looks good.
Old May 31, 2008 | 09:10 PM
I like it,where did you get that hood?
Old Jun 1, 2008 | 12:06 AM
www.northcountryfiberglass.com
87v6Bird
Jul 1, 2018 04:12 PM
xbazzarex
Dec 1, 2015 05:25 PM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
tglennon11
Sep 23, 2015 05:30 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
